build materials
kd8iggtech
build materials
Post by kd8iggtech » Tue Oct 20, 2009 11:24 pm
Can I use iron pipe for a small pulsejet?
PyroJoe
Re: build materials
Post by PyroJoe » Thu Oct 22, 2009 1:28 pm
Hi,
Most steels & irons will degrade from high temperatures. May be relative to how long you want the engine to last.
Thickness of 16 gauge could produce over a dozen runs of 5-10 minutes. Mild steel is a good resource until you have honed what you wish from the design. Then stainless steel can be used for final designs as it is more expensive. If reasonable care is taken the stainless can withstand many years of intermitent running.
Small engines can be difficult for beginners. Happy pulse-jetting and good luck.
kd8iggtech
Re: build materials
Post by kd8iggtech » Thu Nov 05, 2009 1:27 am
Thanks Joe. I have tried several configuratios with the pipe jet, but still wont run on its owm. my fuel mix is tricky at best. Still experimenting and haveing a lot of fun
