Heres an injector style i have been experimenting with ,
This was the only type of injector , that my small engine would sustain on, (bad engine or good injector who knows ?),
Basically you just put the tube in a drill chuck and squash it down
The chuck must be the type with pointed jaws not the semi flat type,
The top left in the photo had dressmaking pins inserted , prior to the final squash , giving 3 small angled holes,
You can file angles on or leave them flat or , well just experiment.
Works for me , give it a try
Triangular injectors
- IMG_0098.JPG (62.74 KiB) Viewed 5368 times
- IMG_0090.JPG (45.34 KiB) Viewed 5377 times
- IMG_0095.JPG (37.71 KiB) Viewed 5377 times
