This is how i usually make the holes in the combustion chamber for the inlet tubes,
It is a very old fashined way of making large or odd shaped holes in sheet steel called CHAIN DRILLING , cut between the holes with side cutters and a little work with a rotary burr and you can produce acceptable holes , this particular hole took me about 10 minutes to make
might be useful to someone, who like me doesnt have a plasma or nibbler etc
MAKING HOLES FOR INLET STUBS
- IMG_0078.JPG (112.6 KiB) Viewed 2189 times
- IMG_0076.JPG (88.96 KiB) Viewed 2189 times
