A couple of vice-grips, a pipe and off you go. Just put a shim of the same material you're rolling (plus a couple sheets of paper optional), and the material fits under snugly.
If you're doing thicker material, then you may need a broad lever (I'm using a galvanized strap in the photo.
I can't recommend highly enough getting a cheap spot welder to tack the lap seam together before welding up the whole motor.
Easy cone rolling
Easy cone rolling
- cone rolling1.jpg (62.78 KiB) Viewed 6396 times
- cone rolling3.jpg (52.75 KiB) Viewed 6397 times
A great way to build the cone roller that was presented in early posts ( Mark's??? ).
Fantastic!!!
How do you roll the sheet?
with your fingers?
i once tried to do that, with a 1mm sheet ( small diameter cone ) , and it was to hard for me ( greese monkey fingers, not the soft type 8) ).
i would like some explanation about the technique.
thank's alot Mike!
yam from Israel.
Fantastic!!!
with your fingers?
thank's alot Mike!
yam from Israel.
Ford Sohc Forever!!!
