i am planning to use a valve grid design on my pulsejet, does the dimentions look ok ?
main chaimber diameter and lenght:
91.4mm lenght 89 mm
cone:
91.4mm opening in front,
lenght is 125mm,
end diameter of cone is 57mm,
exhaust tube diameter is 57mm and lenght is
665.1mm
The two intake ports that leads to the valves is 67.97x25.2 mm
They are spaced 10.03 apart.
The angle of the vale resting plates is 23 degrees
the hole ( or port ? ) in the valve resting plate is 13X35 mm and it is 3 of these holes in eatch plate.
Total number of these plates is 4 .
I have calculated it to deliver aprox. 25kg of trust
I will get the parts cut with a laser cutter.
All materials vill be stainless steel.
Please forgive my misspellings, i am Norwegian and not so wery good too write english. I do not have any problems reading!
HÃ¥ken
Norway
pulsjet question
