Anyone here know where i can get made/cut about 30 SS 1mm discs on the cheap?
OR, even better, any company or individual willing to get onboard with some sponsership and be involved in PJ history??? I need some discs!
Big things are happening here, although the budget is a bit tight on this project.
So close... just need a last part or two, or 30.
Edit... obviously 1mm thick, not diameter. 6" diameter, or there abouts.
Rossco
Need discs
Need discs
I'd go to a largish lokal sheet metal workshop. Chances are that they can just stamp them out for you in no time. If you find one that makes holes of that size into sheet metal for other reasons, such as a company that makes ventilation systems or some kind industrial chemical equipment, they might even have them as scrap metal you can have for free.
SS circles
If you've got a drill press, you can get a circle cutter to make any size circle you want. Go to www.mcmaster.com and search on item 3082A2 for holes up to 7 7/8th inches wide.
Also, you can use other types of hole cutters like item numbers 4008A68 and 4066A75
-Aaron
-Aaron
No, they suck on 304 sheet. Like, one might get you one disk. It's also a quite large die set for a sheet metal shop. The shop I use is all under 3".
Best bet is water jet cutting. Tell them you want to supply the material.
Sounds all a bit suspiciously like a Tesla project... hmmmm... ):-P
