I have a toro electric leaf blower that says "up to 215mph". Since I need to send specific speeds of ram air in my intakes for the work I'm doing, I wanted a rough idea of how far away to hold the blower's nozzle from my inlet.
I went to a buddy's house that builds aircraft and used a pitot tube and indicator, taking readings at various distances.
I put a bit of a conical restrictor on the blower, exit diameter 35mm. The readings were these:
25" 65mph
20" 80mph
15" 105mph
12" 130mph
The indicator topped out at 140, so I couldn't get any closer to the nozzle, but expect that the curve will tell me where the higher speeds are.
I just calibrated my leaf-blower!
Air speed caliberation
Man thats excellent! 130 MPH is damn fast!
How many Watts is this blower rated at?
Haha looking forward to where this thread might lead.
calibrated leaf blower
I'll have to get a airspeed indicator that's up to the claimed speed of 215mph. Here is a plot of the blower on the high setting. I added a data point that would be 215mph at 5" (a lower setting, without nozzle, showed not much change in speed from 5 to zero inches).
I'll update this graph when I get the right indicator, but for the purpose I intend, this is close enough.
- leaf blower speeds.JPG (18.62 KiB) Viewed 7321 times
Re: I just calibrated my leaf-blower!
Can you tell us the pressure readings (in inches WC or mm Hg) from the pitot static gauge that correspond to these velocities?Mike Everman wrote: The readings were these:
25" 65mph
20" 80mph
15" 105mph
12" 130mph
