Whats the easiest way to cut shapes in sheet metal?
I am tired of wasting dremel cutting disks, is there a device I could use to cut out shapes (mostly cones) in sheet?
I am using 22 gauge at the moment, might go down to 24 soon but the 22 is working fine for now.
Cutting metal
Mate I've got a great budget setup at the moment...
Get a nibbler (attach to the end of your drill) blitzes through stuff up to 1.6 mm.
Then get yourself an "angle grinder" (a nice big one for like 20/30 bucks cheap n nasty) and use it to grind off the major excess in a vice. Its rotary metal grinder purely for metal. (GET YOURSELF EAR PLUGS FOR THAT ONE)
Then just use your dremel to clean it up when your right next to the line, i barely use my dremel anymore i can get nice smooth edges with the angle grinder.
I'll attach pics soonish. total cost of setup about 100 us dollars if that. You prolly wont need much else, and grinding blades for the angle grinder will slice through any metal quickly. I've found the pneumatic sheers are only good for 1mm stuff, gotta be able to do more if required.
Gotta find a nibbler, I have shears and an angle grinder (and a pedestal grinder) but getting curves in sheet was the problem. I saw you use the nibbler in a video J, and it looked much easier!!
I use a hacksaw... or occasionally the sawzall, but recently alot of those cutting disks! (I just stick them in my drill press, turn it up to full, and blast away) After a quick, rough cut is finished I use the bench grinder. It's all primitive I know, but it's all I got. Besides, it good for the arms. :D
PS: sorry, but that picture of the metal shears and the pipe is pretty funny.
Cut
Anser: Jigsaw.
Place clamps around the out side edges to reduce some noise. Then use a cheap Jig saw, with fine tooth blades. Makes one hell of a noise , but works.
A cheap one can be had for less then $30.00....
We do it all the time at work. Make the girls swurm........
Jim
Jim
I usually use cutting disk (which sometimes can be a pain in the butt to use) and usually end with an ugly product. But, all the cuts are out of the lines, so, with a little work with the bench grinder they turn out pretty good. However, those inside curves can be a pain...
I personally don't like the dremel tool for cutting stuff like this (though precise) just because it's WAY too slow. However, the diamond cutting disks work pretty good...
xxxx
Zip:
I just place some 2x4 under the work rising it up.....The clamps are just to dampen the vibration of the metal and kill some of the noise!!!
If it is small enough, you can clamp the metal to the table top and clamp around the outside edge to kill the noise...
Jim
Jim
Air nibblers
I am also looking at better ways to cut materials. How good are the air nibblers on stainless? Any experience with the max thickness they can handle?
