titanium valve head
Hveem
titanium valve head
Post by Hveem » Fri Oct 27, 2006 2:25 pm
Is it possible to use Ti-6Al-4V and machine it in too a valve head for a small PJ ?
Dang911
re: titanium valve head
Post by Dang911 » Tue Oct 31, 2006 12:38 am
Sure If you have the tools to machine such a material. You will need flood coolant with any machine operation, carbide C-2 or M42 HSS (preferably coated with TiN, TiCN, TiAlN). Keep the feed rates slow to reduce heat buildup.
Louder is ALWAYS Better!!!
Hveem
Re: re: titanium valve head
Post by Hveem » Wed Nov 01, 2006 6:50 pm
Dang911 wrote:Sure If you have the tools to machine such a material. You will need flood coolant with any machine operation, carbide C-2 or M42 HSS (preferably coated with TiN, TiCN, TiAlN). Keep the feed rates slow to reduce heat buildup.
Thats not an problen, i have acess to a late and a milling machine.. No advanced stuff, all by the good old hand and eyesight.
My only worry is that titanium can be very hard on the valves, since titanium alloys are somewhat similar too stainless steel when machining.
