Odds and ends
Re: Odds and ends
Post by Mark » Sat Dec 21, 2019 12:10 am
Re: Odds and ends
Post by Mark » Sat Dec 21, 2019 5:46 pm
I noticed there's a distortion or heat stress effect of a black band around the Absolut vodka bottle only seen when held at an acute angle. The band goes completely around the bottle from the individually glued on letters on front to the clear plastic ~1 inch wide strip on the back of the bottle. The heat distorted the plastic label but also the label free areas as well.
Perhaps the bottle didn't crack because as it goes down to the pool of fuel, it's not touching the sides so much and at the bottom maybe splash evens out the heat stress there, sort of like a magnetic bottle trying to keep the heat from melting the walls of a fusion reactor. Another thing is the snorkel depth was at first tried at the top of the neck and after watching how the flame breaks as it enters the main body the outcome seemed to make a reverse cone of what you normally see, wide flame on top and narrow at the bottom like a tornado. But by pushing the snorkel deeper to the verge of the main body, the break or fanning out of the flame occurs right on top of the pool of fuel. At any rate how coherently the flame-front holds together or stays focused as it travels the length of the bottle is very important.
For review again
https://www.youtube.com/watch?v=OUsha3uFPAA
I should say the distortion formed in the region where the flame widens. The last photo shows a large area where no letters or plastic label is on the bottle, the back label plastic strip just visible on the top right of the photo.
Re: Odds and ends
Post by Mark » Sun Dec 22, 2019 1:57 am
Absolut French Ending Jam Jar Jet
https://www.youtube.com/watch?v=ImmewZnfjtE
Re: Odds and ends
Post by Mark » Wed Dec 25, 2019 2:36 pm
This conical shape is interesting in that at the top you don't have a lot of blank space with no fire like a typical jam jar. I like how the flame fills the slanted decanter while still leaving a slim gap along the sides where a direct flame might be more llkely to crack a bottle. The bottom is an exception but there there is some splash which might moderate a direct flame to some extent. If you freeze the video you can better observe the cone of fire, with a possible slight bias to one side from the non-vertical angle or imperfect cant of the exhaust tube.
It's a good idea to wear hearing protection with these souped-up jam jar jets. I was getting quite frustrated with the decanter, it took a lot of patience to find what works. One thing to come to understand is if it doesn't start or sound promising after a few tries, move on because most likely you'll waste your time hoping against hope. A few times one shape has started on the first try and ran but then never again. When you run into that, try stepping up or down the length or diameter of the exhaust tube an inch or so. And have other experiments in mind to try so you don't get bored with temporary failures. If you find a good match, these engines can be forgiving.
Decanter Jam Jar Jet
https://www.youtube.com/watch?v=g2ZwuyALwxg
Tongue in cheek wisdom for successful jam jar jetting.
https://www.youtube.com/watch?v=TKOrr4XRbg8
Re: Odds and ends
Post by Mark » Thu Dec 26, 2019 4:53 pm
This caught my eye, a store-bought jam jar jet in "durable borosilicate glass". They are very much like my Princess House oil candle lamp only no busy grass etchings or cone tapered top, a perfect cylinder but you must take caution for the hole might be "energetically restrictive". Wear eye protection if you should experiment with these and plan if it should burst on the initial whoosh, just to be safe. It seems like at least one of the heights offered would have a good chance of performing nicely for a show and tell.
Transcend Glass Oil Lamp
https://youtu.be/zQUhR1ifoAU?t=12
Firefly Pillar Candle Burning Firefly Paraffin Lamp Oil
https://www.youtube.com/watch?v=pNV2XKvXRnY
Just a glimpse of the hole size but it looks neat or well-formed.
Oil Lamp Wick - Trimming
https://www.youtube.com/watch?v=o16F7yE8Muo
https://www.fireflyfuel.com/shop/glass-pillar-candles
Re: Odds and ends
Post by Mark » Fri Dec 27, 2019 9:40 pm
A clever presentation with some inventive tries but running into the school of hard knocks toward the end.
Tesla Pulsejet Engine [3D Printed
https://www.youtube.com/watch?v=28XbT11lL24
Re: Odds and ends
Post by Mark » Mon Jan 06, 2020 2:22 pm
Dead air space and snorkels.
The Death Mask
https://www.youtube.com/watch?v=hilPPJE ... tu.be&t=99
https://www.youtube.com/watch?v=wrHMtLsF2js
The topic brought to mind how the giraffe might get around the problem of dead air space with a 2.3 meter trachea length.
Dead space and tidal volume of the giraffe compared with some other mammals
https://www.sciencedirect.com/science/a ... via%3Dihub
Re: Odds and ends
Post by Mark » Mon Jan 06, 2020 9:22 pm
Another bottle shape just to play around while trying to find some parts for more novel ideas.
Diplomatico Jam Jar Jet
https://www.youtube.com/watch?v=IrIVCNbi0rQ
Re: Odds and ends
Post by Mark » Wed Jan 08, 2020 7:35 pm
A plastic water bottle look for something different. The decibel level was 112 according to the sound meter I bought.
Jesting Jam Jar Jet
https://www.youtube.com/watch?v=hsfdBz1QtBA
Re: Odds and ends
Post by Mark » Mon Jan 13, 2020 8:36 pm
The first time this ran the exhaust tube shifted during the run and it stopped after only 5 seconds or so. But it was nice to see an ordinary wine bottle can become a jam jar jet too.
Here's an old post from 2013 when I first thought about it. In the video review the lid is said to look like a Smucker's jam jar lid.
viewtopic.php?f=10&t=4619&p=77003&hilit ... ine#p77003
Jam Jar Jam Jar Jet
https://www.youtube.com/watch?v=LPe29o0OUSw
Re: Odds and ends
Post by Mark » Sun Jan 19, 2020 12:37 am
Soda Water Bottle Jam Jar Jet
https://www.youtube.com/watch?v=md1rdl2auWI
The El Dorado rum bottle is proving extremely hard to solve. the neck widens and narrows and bottles that are not cylindrical don't seem to channel the flame as much as a typical bottle. It might as well be a sphere which I dislike most of all, the flame front is chaos with more of a non-repeating pathway.
You can see the neck better here, which might also disrupt feedback rather than a straight shot into the bottle as with more common shapes.
https://www.thewhiskyexchange.com/p/447 ... al-reserve
Re: Odds and ends
Post by Mark » Sun Jan 19, 2020 2:42 pm
Speaking of coherent flame fronts from the last post, there was this Coleman heater I took apart in the early days to use the fuel tank as a possible jam jar. It has a pancake shape with about a 1 inch hole in the center which when lit would flutter if fueled with methanol but was unstable and would stop running after a short time. As the flame could advance left or right as it entered the tank, it made for a bad jam jar jet.
One such as this with the catalytic part removed ...
https://youtube.com/watch?v=gKaiYbZLryg
Re: Odds and ends
Post by Mark » Sun Jan 26, 2020 1:08 am
600,000 liters produced per day. 13 million bottles in the storage room. That's a lot of Absolut jam jar jets.
https://youtu.be/KS8auzQ-15E?t=296
https://youtu.be/TMPLmYnSut8?t=165
Re: Odds and ends
Post by Mark » Sun Jan 26, 2020 5:37 pm
It might have been funny to try one of these limited edition bottles that looks like it has already fractured.
"Absolut's new limited edition is made of recycled glass and gives the impression of a crushed bottle. This design creates awareness and encourages people to change. Absolut shows that we can transform something unwanted into something beautiful."
https://www.heinemanndutyfree.com.au/en ... 001410791/
And then maybe have it really fracture such as this one.
Re: Odds and ends
Post by Mark » Fri Jan 31, 2020 2:04 pm
I was going to try to have quirky quartz shape made but ran into a delay.
Hi Friend,
Sorry but we are now on Chinese Spring Festival holiday and we China are fighting the novel coronavirus in the meanwhile. So our manufacturer will have a long holiday till after Feb 10.
Could you send us a ebay message again on Feb 10 and then we'll ask the manufacturer if they can supply it as you need?
Regards,
Sunny
