EBay musings
re: EBay musings
If you want to see lots of Stainless steel and machine tools to hack it into something hot & noisy, check out www.sas.net.
Also, Penn State's creamery is liquidating its ice-cream making equipment. More stainless than you can shake a dilly bar at and a few fridges that will make your neighbor jealous that he only has a whimpy little Sub-Zero.
http://www.surplus.psu.edu/Creamery%20Main%20Page.htm
Re: re: EBay musings
WOW! I creamed my pants after a look at the creamery equipment. It is all high-grade steel, too. Normally very expensive.pezman wrote:If you want to see lots of Stainless steel and machine tools to hack it into something hot & noisy, check out www.sas.net.
Given the run of that facility, I think the participants of this forum could build a veritable air force. Kind of opposite to the 'swords to ploughshares' cliche, don't you think?
Creamers to screamers? Dairy to airy? Or, in less successful cases, butter to splutter?
re: EBay musings
rofl
that Z jet is an incredible work of art!Mark wrote:http://tinyurl.com/hdjf2
re: EBay musings
On picture 4, if you look at the retainer at 3 o'clock I believe that little hole is a pressure tap to help drive the fuel system, along with aspiration from the vacuum in the throat it also gets pressurization bled from the combustion chamber. Or at least I remember one of his designs with such a philosophy.
re: EBay musings
Hi,
Check out Erics advanced Lockwood style plans :
http://cgi.ebay.com/ThermalPulse-180-AD ... dZViewItem
Al Belli
Al Belli
re: EBay musings
Hagen Tannberg
What's a tumbler? Looks like a cup. I wonder if it's open on both ends. Any ideas on the size?
Thanks Mark
Hagen Tannberg
