Induction coil
Induction coil
Post by Mark » Thu Dec 23, 2004 3:54 am
This is very similar to the Model T buzz coil philosophy, and something anyone could build easily enough. And it is very reliable.
http://cgi.aol.ebay.com/ws/eBayISAPI.dl ... eName=WDVW
Heath Daily
Re: Induction coil
Post by Heath Daily » Thu Dec 23, 2004 7:15 am
You can do that with an old points style automotive coil and just about any normally closed relay. Power the relay though itself and it will pulse very rapidly. Use that pulsing power to run the coil and don't forget the points style capacitor hooked to the pos side of the coil.
I have used the blower fan relay from 70's though 80's era chevys and they work very well.
pezman
Re: Induction coil
Post by pezman » Thu Dec 23, 2004 1:48 pm
A small bug-zapper from Walmart will do about as well and costs about $14.
At 27000 volts though, you're getting close to the ability to generate corona discharges. Not sure an amateur could build a corona discharge ignition, but it's a pretty interesting technology.
