Fancy hubcap or lawnmower blades
If you ask me, $1200 US for all that stuff is a bargain. Think of the hours of machining that went into making those objects. If that stuff was airworthy it would cost tens of thousands, I'm sure. I'm surprised nobody bid. If he would have accepted bids from Canada I might have plunked down some kingo on it myself. Just because he doesn't ship up here doesn't mean I can't have it shipped, although there might be some kind of export control on that stuff. Perhaps he will re-list it. The entire third stage of a low-bypass turbo-fan would make a fantastic toy I think. There are all sorts of things that are worth way less that cost way more. Fancy mag wheels for Honda Civics come to mind, as do riding lawn mowers.
airworthy???
I'm sure hes just saying it's not airworthy to avoid being sued if some idiot fits it wrong or something.
I reckon if you shove it into an engine...ti'll run with no problems.
BURN!!!
maybe...
yeh...i suppose it may be cracked or something.
However, if you look at old engines or other equitment on ebay, they all say "due to the nature/age of this device it is sold as a non-functioning collectable only"
Man...you should see how many of these "non functioning collectables" i have runnning. Mind you ...they are piston engines and not jets, but still.
All i'm saying is that if i had that engine, with the part being sold missing, i'd shove it in there and see what happens. but then again...that's just me :-) . I'm crazy. I made a diesel injector head out of a doorbell button!!
BURN!!!
I can assure you that, at least in the US, 'not airworthy' does not necessarily mean that something is incapable of being used and performing well. If a main bearing in an engine is miked at .001 inch out of tolerance, the mains get replaced -- never mind that with normal lubrication, they'd still work fine for another 1000 hours or more.
The demands of airworthiness, especially when you're talking about powerplant parts/subassemblies, are incredibly rigorous in comparison with automotive requirements, for example.
And of course, even then, there are the occasional failures. Like a casino, the laws of physics sometimes pay, but they never lose.
