Check this out... ATDI GS - 80 Turbojet
This engine is the result of a joint effort with Advance Turbine Design and Orbital Machine Works, although designed for use as a Glider sustainer propulsion system, this engine would be suitable for many other applications such as propulsion systems for UAV's, Experimental aircraft, the engine core could also be developed into a Ground power generation unit up to 50kw. This technology has been previously demonstrated at Advance Turbine Design. With it's robust construction and the latest state of the art micro turbine technology and hundreds of hours of both ground and flight testing this turbojet is a proven performer.
Website you might find of interest thats dedicated to the design and development of gas turbine engines-
http://www.advanceturbinedesign.com/Atdi80.aspx
