Combustion chamber
Re: Combustion chamber
Thanks guys.
Yesterday I bought a S400 turbo from scrapy yard.
The compressor has some corosion, but i think, it should work.
Now Iam trying to find information about it.
Here is unfinished drawing:
there is no clasical solving for combustion chambers because of very complex CFD analysis and conditions.only some empirical tests are available!
for CC designing you must have a lab!
B.R
B.R
I decided to make CC big as posible, and thats all.
I have two sides metal covered bearings, is it good idea to keep outer side covered?
I machined diffuser plate:
Maybe anyone knows what angle is "the best" for NGV blades? Or how to find it?
Hi
You'll need to do the maths to workout the throat areas and from that the actual NGV angle , it'll vary depending on a multitude of variables , but something around 20 -25-30 degrees should be OK
John
John
Hm, first solution i think is to difficult to me. I think I will use ~25degrees
I made some progress on the engine:
Looking good! I´ll follow this build with great interest.
Thanks, Johansson. Today I cut slots in NGV for vanes at 25degres. Its my first jet engine, so Iam not going pretty fast
This is what I have done at this moment:
The CC loks terrible and its made from 0.5mm sheet metal. But it's only for testing. Now it hasn't got any vaporizing tubes, becouse I will test engine on propane. If engine will run good, I will make the CC from stainless, and of course, with vaporizing tubes.
Well, i made few tests, but all times i had flame out, but only in one side, about 45degrees of circle. For fuel Iam using LPG gas. I add sketch to understand the problem.
I hope, you can help me :/
Have you got a better drawing of how the combustor is build, what does the propane injectors look like and how are they positioned for example?
