My buddy wants to build a turbine powered boat and I was wondering if pumping water onto the turbine could extend its life? In the water you got a hopefully near endless supply of the stuff...
Would misting it onto the turbine wheel help at all or is there a more efficient/complex method?
Turbine Cooling ?'s
Turbine Cooling ?'s
Re: Turbine Cooling ?'s
Hi
Please don't spray water on a turbine wheel , it'll probably wreck it .
A properly designed turbine engine shouldn't run temperatures too hot for its turbine wheel to handle .
Adding water to a turbine engine can be more trouble than its worth because of the changes it makes to the configuration between wet and dry running .
Why are you contemplating this drastic measure ??
What engine are you intending to use?
What are its temperatures?
John
John
Nothing in the works, just wondering. Hobby turbines dont last as long as big expensive one b/c of cooling so we though there must be some way to cool a hobby turbine with all the water available in a lake.
Guy I talked is almost done with his 6 stroke piston engine, he uses water as the cooling and fuel for the final 2 strokes. Was wondering if there was a way to apply this to a turbine; such as some way of mixing the hot expanding/burning gasses with water for some flash steam and a bit cooler turbine running temps.
my comma button is broken it took 15 mins to add them to this post.....lol
Oh I forgot, the reason it came up was I have always used the cut and bend your own axial turbine method from the shrecky book. Never bought an Iconel one.
My Stainless Steel ones only lasted a few hours at the most.
Yeh , homemade turbine wheels can be a problem , unless made well , their efficiencies are so poor that the engine has to run high temps so as to provide sufficient power to turn the compressor .
Better off using turbocharger bits to make the engine, like I did with my FM-1 engine... http://www.racketmotorman.turbinebuilde ... hp?album=2 ,....... TOTs are down in the 500 - 600 deg C range even though producing ~60 lbs of thrust at 85% rpm potential , expected thrust ~100 lbs at full rpm of 66,000 .
Plenty of ways to make reliable turbine engines using turbochargers
John
John
Is the wheel made of metal or is it cermaic? Worked on many turbos over the last few years and came accross a few silicone-nitride ones. SHould have stolen them
Do you have a better source for turbo wheels than ebay?
A lot of truck and auto turbo turbines are made from GMR235 or Inconell 713 , both "super alloys" capable of withstanding high temps , up to ~900 deg C turbine inlet temps .
But an engine is the total of all its parts , unless all components are working efficiently the engine won't perform , no point having a high temp turbine wheel if the compressor is running out of its design limits , and/or the combustor isn't producing a nice burn without flames in the turbine .
Most of the larger turbine overhaul shops have "bits and pieces" that could be used in a homemade engine , but aren't up to the standard for going back into a turbo which will see thousands of hours of use . You need to hunt around a bit )
John
John
