can't get it self sustaining.... Any ideas why???
I have built a gas turbine that doesnt become self sustaining..
Possibly there are too many holes that i have drilled on my flame tube...
Is it really a problem???
A little help please....
Iam using this turbocharger and running it on gas..
- cat_eating_turbo[1].jpg (12.43 KiB) Viewed 11355 times
Maybe you have a blockage stuck in it. Is it blowing chunks of fur? this would be a good indicator of foreign body ingestion.
Seriously tho. You need to show much more detail for some help.
I am no expert, by far, although i can say YES, the flame tube is very important. Put up some specs on it, and there is some very knowlegable people that will help.
And remember to remove the intake cover/cat before running.
Rossco
Rossco
Hi Jason
What are you using for a starter ??
Larger turbos "generally" have reasonably matched comp/turb assemblies so the turbo itself can be discounted as the problem unlike some small auto turbo which won't start because of serious flow mismatching betweenn comp and turb .
How much fuel/gas are you supplying?
At what pressure?
Turbines are extremely thirsty beasts , and you're running a decent sized turbo , so give her plenty of gas , by "gas" I hope you mean propane (LPG) not gasoline (petrol) .
With a strong enough starter and plenty of fuel she should scream :-))
Tell us more
John
At what pressure?
Tell us more
John
Well thats ya problem mate!
Well thats ya problem mate! there in a nut shell see, yur CAT supposed to come after the Turbo on the exhaust side see! not the inlet
Corse it wont work like that now willet!
Viv;-)
Viv;-)
Hi Jason
Remove the regulator immediately , it'll only supply a very low gas pressure to the combustor , once the engine starts to spoolup a bit ,it'll be producing an air pressure within the combustor "higher" than the gas supply pressure , effectively shuting off the gas supply to the engine .
If your gas pressure downstream of the regulator is <1psi and "normal" idle air pressure (P2) is 4-5 psi , its pretty clear that the 1psi isn't going to work , you need full cylinder pressure, which can be up to ~80-90psi .
You'll also be needing a metal supply line(copper pipe) at least 1/4 inch diameter , with a ball valve in it for fast shutoff in case something goes wrong , the normal cylinder valve will take too long to screw down in an emegency .
Your engine is pretty big so it'll be needing lotsa gas at full bore :-))
All the best , enjoy the "noise "
John
John
You guys got it all wrong ...
Naaaaaaaaaa ...
You guys got it all wrong .....
That's a JetCat ... Hé hé hé .... (http://www.jetcatusa.com/) .... LoL :-)
Cya,
Luc
Cya,
Luc
