new to the board
BEANIE
new to the board
Post by BEANIE » Thu May 17, 2007 9:40 am
I just wanted to say hi, I have just finished building my jet powered go-cart is has got electric start and a ajustable nossle. Here is a couple of pics of it
bean pic 1.jpg (70.13 KiB) Viewed 5522 times
BEANIE
Post by BEANIE » Thu May 17, 2007 10:01 am
pic 2
beanie pic3.jpg (68 KiB) Viewed 5520 times
BEANIE
Post by BEANIE » Thu May 17, 2007 10:04 am
pic 3
beanie pic 2.jpg (63.32 KiB) Viewed 5518 times
racketmotorman
Post by racketmotorman » Thu May 17, 2007 10:37 am
Hi Beanie
How does that "nozzle bullet" cope with the afterburner temperatures , is it liquid cooled ??
John
Johansson
Post by Johansson » Thu May 17, 2007 3:12 pm
Nice cart! I am also curious about the variable exhaust nozzle, without cooling it would get mighty hot...
//Anders
BEANIE
Post by BEANIE » Fri May 18, 2007 9:26 am
yes it does get very hot but it is made out of 316 stainless steel and the heat doesn't seem to affect it. The nozzle restricter is activated by a waste gate actuator so when you start the jet up the restrictor is forced out into the nozzle and when you hit the after burner switch it also activates a solenoid which bleeds the pressure off in the waste gate actuator line, and the restrictor retracts. My cart has got 36 pounds of thrust dry and 55 pounds with the after burner.
Johansson
Post by Johansson » Fri May 18, 2007 12:18 pm
That is great numbers, have you measured the tailpipe pressure to find out if the nozzle restrictor keeps the pressure constant regardless of P2/afterburner use? A really smart sollution!
//Anders
