KJ-66 model build project
heloooo
Hola rosco I and made mas of 3 kj66 and I am in possession of making the new one of 73mm of compressor. have chamber(camera) of 12 injectores for jg 100, we can share route msn things, but I translator of Spanish, Englishman
toma
mas photos
- 40.jpg (80.55 KiB) Viewed 19707 times
- bee artesjet 50mm
- 10.jpg (63.26 KiB) Viewed 19703 times
- my minibike and 3 kj66 1 blue , 2 red
- 09.jpg (74.18 KiB) Viewed 19704 times
- otra clon kj66 home made manolo
- (142.75 KiB) Downloaded 391 times
- bee and kj66
- 11.jpg (35.17 KiB) Viewed 19710 times
Spanish, i need some lessons!
Hola MANOLO,
I only speak Australian, which is not even very good english.
Your English is much better than my Spanish!
Im sure that i will learn a lot talking to you.
I think that we could get along ok.
My MSN is gordonross308@hotmail.com
Put me into your contact list, and we will see how it goes.
Jason, i would say that the turnine wheel of Manalo's is cast, then machined. Probably inconel or something too! Have a look around the forum, i think he has some description here. If not, someone went into detail of it a while ago, Ash maybe?
HELLO
HOLA ROSCO IN END(PURPOSE) IF MY WHEELS OF TURBINE ARE OF ARTESJET's INCONEL, MADE OF SPAIN FOR ARTS I JOUST IN MY COUNTRY, THE FIRST MANUFACTURER Worldwide, THE KJ66 MADE IN SPAIN. BECAUSE OF IT I HAVE THE LUCK OF WHICH I LIVE IN THE SAME COUNTRY AND THE THINGS ARE EASY TO OBTAIN
I use ANSYS it has wide range of modeling, meshing, solving tools.
ANSYS even have add-on special for turbine design- BladeModeler for design and TurboGrid for meshing.
take a look at this great software brochure:
http://www.ansys.com/assets/brochures/b ... ler-10.pdf
http://www.ansys.com/assets/brochures/turbogrid-10.pdf
I have done some airfoil design testings at high speeds(Mach 2+), now I am learning blade designing.
Regards,
Kestas
Kestas
Hi Kestas,
Sorry, i missed your post before.
I am also using Ansys, recently moved from Cosmos, although it is a very hard learning experience.
I look foward to speaking with you on the subject, you can contact me on any of the programs listed bellow.
I cannot share that particular design, as it was for another project, and done in Pro E, although i have other disigns that i could model for the purpose.
Hope to talk soon,
Hope to talk soon,
Hello,Rossco wrote:Hi Kestas,
Hope to talk soon,
COSMOSFloWorks is great for simple design testings as it has wizards and intuitive interface, I even didn't read help for first sim:) But it lacks functionality for real-world turbojet engine design testings. Also ANSYS can interlink several analysis on same model, SolidWorks COSMOS* is not capable doing that. Also, it is very important for gas turbine design testing, ANSYS is capable simulating combustion.
ANSYS is harder to learn, but easy to use. ANSYS has very good documentation.
Many modern jet fighters(F-16(recent modifications), Joint Strike F-35, etc), airliners(airbus a380) and *jet engines have been tested on ANSYS before real-life testings.
ANSYS is also compatible to modern supercomputers, mainframe computers and computer clusters.
http://www.ansys.com/industries/documen ... -spr06.pdf
Regards,
Kestas
Kestas
Rossco wrote: <..>
Hope to talk soon,
What formats ProE is capable saving/exporting ? As far as I know ANSYS is capable importing from ProE.
Now I am designing KJ66 turbine on CAD too, if you share your great work, we can save time and do simulations and design improvements together.
I am using UGS NX 5 & ANSYS BladeModeler for design and ANSYS 11 for simulations.
http://en.wikipedia.org/wiki/NX_%28Unigraphics%29
Regards,
Kestas
Kestas
Ah, yes, Ansys is fully compatible with Pro E, although thats not the problem.
That engine was done in about 3 different programs, from 5 different designs.
There was a lot of shortcuts made, and most things that i could not get information from the plans for, where done by eye. (including that compressor, im looking foward to getting into turbogrid too)
I dont even have Pro E installed on this machine any more, so i shall have to import parts (assemblys dont import!) to salvage anything out of there...
I think that it will be a start again project really, and if we are to put our heads together for this one, then it would be best to start from a common place. Comunication has to be a little more versitile than a forum, post by post method too.
