importance of compressor bellmouth DP
ibanez
Post by ibanez » Mon Jul 31, 2006 8:55 pm
can someone explain the significance of the compressor bellmouth differential pressure and why is it measured?
I know the inlet DP is measured to give an indication of the cleanliness of the inlet filters
racketmotorman
re: importance of compressor bellmouth DP
Post by racketmotorman » Tue Aug 01, 2006 8:56 pm
Hi Ibanez
The static pressure difference between inside the bellmouth throat and static ambient pressure will give an indication of the mass flow as the total pressure will remain the same , the static drop converts to a dynamic component (velocity) and along with the flow area will give mass flow of the less dense inlet air .
Mass flow = speed X density X area
Hope this helps :-))
John
