easy to build
easy to build
does anyone have a design for an easy to build turbine that doesnt require many exotic materials (no car turbos)?
re: easy to build
no scrap yards within 50 miles...exotic wud be sumthing not easily accessed, i have access to all kinda of metals and milling equipment but nuthing pre made like a turbo
re: easy to build
How much time can you spend on building the turbine? A microturbine like the Kamps design is an option, it will take lots of time to build and you still have to buy a compressor wheel. One of Kurt Schrecklings older engines used a home-built wheel from plywood, but buying a wheel from a turbo instead would save you lots of time and grey hairs... ;-)
//Anders
//Anders
re: easy to build
hmm...how hard is it to mill a compressor?
i have complete access to a machine shop with lathes cnc and other mills...wud it really be easier just to buy one?
re: easy to build
Yes buying a compressor wheel and turbine wheel, would save you a lot of time.
re: easy to build
50 miles isnt far. Check local diesel truck shops, cars shops etc etc.
used/junk turbos are very easy to find.
w00t
re: easy to build
re: easy to build
i have heard of people using the compressor off of a vacume or a leaf blower beacuase it is larger than a turbo compressor. is the compressor the only one worth buying or should other parts be purchased also?
