Horace -skyfrog wrote:Hi Alex,
Your propeller looks very nice. To my knowledge, investment casting method is good for parts which dia smaller than 200mm only, I guess your propeller is largely bigger than that.
This part will be cast in Inconel 713 (vacuum melted) by ordinary gravity method.
The only way I have seen investment casting done was where you need to make a new pattern and a new mold every time you want to make a new part. This was custom jewelry work, and so the one-off process was quite acceptable. Is this also true of your turbine, or do you have some way of doing this with permanent, separable molds that can be re-used?
The way we did it was to pour a high-temperature 'plaster' around the pattern and let it harden, then evaporate the wax out of it in an oven. Finally, the gold was melted in a special crucible and the molten gold was rammed into the mold with a centifugal casting rig, and the plaster mold [weakened by the heat it had endured] was easily broken away. Then the piece was polished, plated, and otherwise finished up.
And Alex, yes, the screw [propeller] is very nice indeed.
