for the record does the nose cone for a pressure jet need to be shaped? or can it be flat. if it can what effect would it have on the thrust.
what is the simpolest jet to build and where can i get plans. free if posible.
constrution questens
Re: constrution questens
Hi John,
As for your question about the simplest jet to build and free plans, you can always try to build a pulse jet, there is alot of models around, with free plans.
Now, if you want to build a pressure jet and the nose cone and plans are an issue, you can always get only the cone from us. As you know, we offer with any pressure jet major parts purchase, a free set of plans of your choice, as a promotion. Next to that, I don't know.
Cya,
Luc
If you go back to my original presure jet topic, the 130R power failure thread, you will realize that I have tried a flat nose of the pressure jet and the results were not good and I lost the thrust.JOHNEP wrote:for the record does the nose cone for a pressure jet need to be shaped? or can it be flat. if it can what effect would it have on the thrust.
Cya,
Luc
Luc
Designer & Inventor
Designer & Inventor
re: constrution questens
thanks for the info i will definetly try a pulse jet. i am cind of a cheep person becaus i dont have much spending $ but i have acces to free metal so i like to biuld stuf my self.
