I downloaded those plans for the pressure jet that can be found on the homepage of this site, and I was annoyed at how the picutres were laid out. I decided to do something about it...
(Sorry for the large file size, I haven't resized it yet.)
FULL plans for the Pressure Jet page...
- (1.94 MiB) Downloaded 2814 times
re: FULL plans for the Pressure Jet page...
Nice work:-) would a moderator make this a sticky so its easy to find please
Is the pressure jet something like a torch?
Re: re: FULL plans for the Pressure Jet page...
Not quite. It's a slightly different and slightly more complex form of pulsejet. It is a torch inasmuch as any jet engine is a torch.Rambo wrote:Is the pressure jet something like a torch?
does this type of jet also produce thrust from the intake? can the intake be bent?
hi nickc .
look like you have a lot to learn about presure jet .
the intake don't produce thrust from the nozzle , what came out of the nozzle it's super heated propane a sonic speed .
the intake can't be bent .
patrick .
patrick .
Re: FULL plans for the Pressure Jet page...
Thank you so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so so very much
