5 pounder questions
JOHNEP
5 pounder questions
Post by JOHNEP » Mon Feb 14, 2005 3:23 pm
can copper pipe be used for coil and hot gas line on the 5 lber?
how do you make the nose cone for the 5 lber?
any other suggestions?
Re: 5 pounder questions
Post by Viv » Mon Feb 14, 2005 3:49 pm
No you cant use copper pipe as it would melt! the engine runs at 1700f so the only option is 321 grade stainless steel.
Using a lower grade stainless will result in carbide precipitation in the metal leading to cloging and cracks in the coil.
The coil contains 100 plus psi so the coil not only has to with stand the heat it has to stay strong enough at 1700f to contain the pressure.
A cracked coil in a running pressure jet is a sight to behold!
Pressure jets should be made from 321 grade stainless.
The nose cone is made on a metal spinning machine, basically a circular plate is spun and then formed over a mold of the required shape using a spining tool.
we supply nose cones and other parts for pressure jets.
JOHNEP
Post by JOHNEP » Mon Feb 14, 2005 4:35 pm
thanks for the advise Viv
how do you access and orter those parts?
luc
Post by luc » Fri Feb 18, 2005 3:32 pm
Hi John,
I am Luc ... Viv's partner.
JOHNEP wrote:thanks for the advise Viv
If you want parts for your pressure jet, go to our Website at www.glc-inc.ca, at the "Contact us" page and send us a quote request for the parts you want.
I wil process that in minutes and send you price figures.
You will be stund how cheap they can come, up to the point where you will probably ask your self ... "Why should I make them".
As an exemple, our pricing for a 20 pounder nose cone is $70.75 CDN, including top quality SST-321, labour and mark-up ... Yeap, no kidding and no catch behind this ... $70.75 CDN for the 20 pounder nose cone.
Depending on your actual location, the only additional fees are shipping and taxes (If applicable).
I hope this helps,
Best regards,
Luc (For Viv)
Luc
Designer & Inventor
JOHNEP
Post by JOHNEP » Sat Feb 19, 2005 1:50 pm
i am wondering if st steel rivets can be used to assemble this jet insted of welding?
Post by Viv » Sat Feb 19, 2005 2:04 pm
JOHNEP wrote:i am wondering if st steel rivets can be used to assemble this jet insted of welding?
No sorry, rule one of pulse jet construction is no leakes!
