When I was 14, I stumbled upon the plans for the 20lb. Gluhareff Pressure Jet on UnitedNuclear.com. My main interest was pyrotechnics and rocketry at the time, but I couldn't not help but buying the plans for $20. http://www.unitednuclear.com/jetplans.htm
After some more research I began construction of a crude jet. My welding and sheet metal skills were lacking. I never finished that jet because of problems with welding the heat exchanger coil. I became discouraged and took a break and resorted to several of my other hobbies at the time.
Before I even got to the heat exchanger coil, the local newspaper did a very nice article on the cart and myself. Although the mixed up some terms and facts it is still fun to read. I have the article scanned onto my computer but it is like 15megs.
The next year, I started up the project again (I am now 16). With the proper materials and more experience in sheet metal fabrication I was able to do it right, or at least, to the best of my ability. Damn that stainless is hard to work with... The hardest parts of the G8-2 are definitely the nosecone, and installing the heat exchanger coil. I'll whip out the whole 3-stage intake and diffuser assembly in a day but forget that coil.
One tip if you plan on building the G8-2, unless you are a master tig welder, use stainless compression fitting for the coil and fuel system.
The nosecone.... ah, yes, the nosecone. I attempted to spin the nosecone on the lathe, which I found nearly impossible with the type of S.S. sheet metal I was using without heat. With my setup, I was not will to use the torch and the lathe at the same time. After several different methods of trying to fabricate the cone, I said "What the hell", and I shelled out $105 for a professional one directly from Irina Gluhareff.
The next day Irina contacted me and told me that her supplier was backed up, unfortunately. But talking with Irina will be worth the wait. She sounded surprised that someone actually bought one, and delighted when she learned that my jet was complete with the exception of the nosecone. She is a very nice woman and it was a honor to speak with her. I look forward to talking with her in the future.
Below are the pictures of my jet, and the go-cart. I read through all of the pressure jet threads here lightly. I would appreciate any input or advice. Thanks!
http://www.pulse-jets.com/phpbb2/album_ ... _id=100013
