my first ramjet
jimbob33
my first ramjet
Post by jimbob33 » Wed Jan 02, 2008 6:00 am
hi i'm new, but i've recently built a ramjet from 16 gauge mild steel. I used alot of ideas from the maggie muggs, and glenn olsen
the cones before final welding, sizes, diffuzer 1.5in entrance 3.0in exit 4in lenth, CC 3.0in dia. 4.5in lenth. nozzle 3in entrance 2.125in exit.
(984.39 KiB) Downloaded 299 times
final welding on body is done
(993.7 KiB) Downloaded 242 times
the inital design was changed for a removable flameholder design by cutting the diffuzer and part of the CC
(966.93 KiB) Downloaded 213 times
the mock up for the removable flameholder design, a ring of metal that slips over the CC.
(986.29 KiB) Downloaded 224 times
the finished design minus flameholder.
(981.99 KiB) Downloaded 234 times
stands are made.
(916.74 KiB) Downloaded 222 times
the finished stands.
(967.89 KiB) Downloaded 252 times
the flameholder (later modified), fits inside the ring on the diffuzer which butts up againist the CC.
(998.99 KiB) Downloaded 299 times
the finished product.
(885.95 KiB) Downloaded 338 times
the retention screws are installed
(990.18 KiB) Downloaded 420 times
love, peace and chicken grease.
jimbob33
Post by jimbob33 » Wed Jan 02, 2008 6:19 am
the rest. video coming soon.
the fuel tube and needle valve.
(1001.08 KiB) Downloaded 264 times
a different flame holder covers 30% CC cross area.
(995.06 KiB) Downloaded 237 times
ready to test.
(981.17 KiB) Downloaded 241 times
best run of the day
(982.39 KiB) Downloaded 318 times
Post by larry cottrill » Wed Jan 02, 2008 2:45 pm
jimbob -
Man, that is fabulous!
NICE JOB! Hope you can get the videos set up soon. What power is your blower, and what flow speed is claimed for it?
You nicely fixed the three greatest flaws in my original Maggie design: The suboptimal diffuser, the crude flameholder, and (of course) the glued construction. Looks like you ended up with something you can really be proud of!
Congratulations!
jimbob33
Post by jimbob33 » Thu Jan 03, 2008 1:34 am
thanks larry, i'm using 250 mph electric blower but i have a speed control so i
have compleatly adjustable speed, so far i can only get up to less than half thottle before a flameout, i think i need more fuel, i have a propane regulator setup so i have as much pressure as i need, but my fuel orffice is only .056 in
but i also need to "port" the valve body out. also i am making a thrust cart as i speak.
jimbob33
Post by jimbob33 » Thu Jan 03, 2008 1:40 am
heres a vid
ramjet001 small.wmv
this is the first run with a .030 in fuel orffice. the flame looks way better now. to bad theres no sound.
(1.87 MiB) Downloaded 3313 times
jimbob33
Post by jimbob33 » Fri Jan 04, 2008 1:55 am
today i tested my ramjet on my new thrust measuring cart, and THRUST!!!!!
at 20% thottle the engine slowly moved forward towards the blower. YES!!!
Post by Bruno Ogorelec » Fri Jan 04, 2008 6:43 am
jimbob33 wrote:today i tested my ramjet on my new thrust measuring cart, and THRUST!!!!!
Congratulations! Yes, this is it! A true ramjet. Feels good, doesn't it? Looks nice, too. A very good effort.
Post by larry cottrill » Mon Jan 07, 2008 2:04 pm
Yes, very nice indeed! That's really a nice air source to have available.
Just curious: Why is there NOT sound on the video file? Every once in a while someone posts a silent video, and I'm never sure why this is the case.
A nice picture of your engine in action, though! With the air source you have, you might be able to do one even larger someday.
jimbob33
Post by jimbob33 » Tue Jan 08, 2008 4:54 am
its a older digital camera so it has no sound but im working on geting one with sound.
