Ramjet = pulseengine?
Robin
Post by Robin » Wed Jul 19, 2006 10:54 pm
Hello! Does a ramjet has a continiued flow of gas like a jetengine, with differens that the ramjet uses speed (outside pressure) to "charge" it or does it work like a pulse jet.. 2-stroke = suck,squeze then bang and blow.
Sorry for the terrible grammath and spelling.. Im from sweden ;)
Mvh
re: Ramjet = pulseengine?
Post by Mark » Thu Jul 20, 2006 12:16 am
According to Foa, subsonic ramjets benefit from pulsating combustion. He says the line of demarcation between a subsonic ramjet and valveless pulsejet is blurred. Frog/toad moth/butterfly alligator/crocodile type of thing.
(787.12 KiB) Downloaded 487 times
Najm
Post by Najm » Thu Jul 20, 2006 5:35 am
Don't valvelesss pulsejets also benefit from the ram effect when they are moving through the air?
Even if a subsonic ramjet has pulsating combustion but no resonance is ocurring so it can't be regarded as a true pulsejet engine.
How do ramjets benefit from pulsating combution?
multispool
Post by multispool » Thu Jul 20, 2006 10:48 am
It's probably little to do with resonance, more likely a cycling phomenon of the burning pattern, some of the old miniature turbines gave a quiet pulsing sound when the compressor was surging, probably much the same thing going on. Whether it's disirable in a sub-sonic ramjet, i have no idea!
Re: re: Ramjet = pulseengine?
Post by Mark » Thu Jul 20, 2006 12:56 pm
Najm wrote:Don't valvelesss pulsejets also benefit from the ram effect when they are moving through the air?
Mixing. I'll see if I can find the paragraph. Does anyone out there in pulsejet land have Foa?
Post by Mark » Sat Jul 22, 2006 2:14 am
Thanks Ben. The paragraph mentions the line of demarcation bit about valveless pulsejets and subsonic ramjets being blurred... Also it talks about the subsonic ramjet benefitting from pulsating combustion.
Post by Mark » Sat Jul 22, 2006 1:47 pm
Thanks for digging that up Ben.
