Viv,Viv wrote:We should get Kenneth to allow html file posting so we can post the vuiewable interactive file.
You can post the eDrawing html file if you first convert it to ZIP...as I did in this thread.
Proposed No-Weld Logan
Good point but i wanted it to work in the window right off the back like:-)PulseDuuude wrote:Viv,Viv wrote:We should get Kenneth to allow html file posting so we can post the vuiewable interactive file.
Stupid me! I never thought of that! Jesus, sometimes I'm really slow witted....Mike Everman wrote:Perhaps you can put the photos in your personal gallery, then put that URL?
Ray, if the tube is, say, 4 inches in diameter, and you plug one end, mark a spot about 16 in from the plugged end and start sawing the tube across at that point. Don't saw it all the way through, but only halfway -- to the depth of two inches or thereabouts.Ray(in England) wrote:Bruno,
Please just confirm I've understood your below instruction correctly.
By 'half diameter' do you mean sawing a slit which is a quarter of the tube's circumference long?.As opposed to sawing a slit of half the circumference's length?.
'About four diameters from the plugged end, saw the tube across to perhaps half diameter with a hacksaw or whatever.'
Thanks, Ray.
My experience with it was early, like my first fuelling attempt. I now know it was not successful because the diameter and location are important and can't just be TLAR, at least my TLAR. And it could have been that it was a stinger in the slit-like smashed Kazoo intake, and partly that it shouldn't be hand-held. Bill hit it dead on with his stinger.Bruno Ogorelec wrote:Ray, I would be wrong in advocating anything specific here. The problem is that I think such a fuel feed makes great sense, and have arguments in its favor, but in actual practice few designers have used it. I don't know why. It could well be that some factor I am not aware of works against it. I just don't know. I wish I could investigate this and find out.
