Another Thermo Jam
jamjarjim
Another Thermo Jam
Post by jamjarjim » Tue Aug 12, 2014 11:15 am
Hi Folks,
I am trying to post a video of my Thermo-Jam. Will the forum allow attachments in .mp4 format????
Has anyone else made one of these fantastic little engines?
All credit to Ghrey for sharing his work with us, Thanks man 8)
Regards, Jim
ace_fedde
Re: Another Thermo Jam
Post by ace_fedde » Wed Aug 13, 2014 10:34 am
There is a limit for the amount of data, but I don't know how much. Post it on Youtube and put the link in your post.
Fedde
jamjarjim
Post by jamjarjim » Thu Aug 14, 2014 10:08 pm
Thanks Fedde, I will see what I can do :)
jamjarjim
Post by jamjarjim » Tue Aug 19, 2014 9:04 am
Just a quick metal jamjar video :D
Not the longest run, but quite energetic!!!
video-2014-08-16-21-55-08.mp4
Tin can
(1.94 MiB) Downloaded 248 times
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 9:54 am
Here's some video for you guys!!!
ThermoJam.mp4
A good look at my Thermo-jam
(1.89 MiB) Downloaded 199 times
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 9:59 am
Thermo-jam with different lengths of pipe. The lengths are given in millimeters in the filename of each vid.
450mm.mp4
450mm
(1.89 MiB) Downloaded 230 times
680mm.mp4
680mm
(1.89 MiB) Downloaded 223 times
880mm.mp4
Longest 880mm
(1.85 MiB) Downloaded 210 times
150mm.mp4
Shortest 150mm
(1.91 MiB) Downloaded 213 times
As you can see, there is not much difference between how they run.
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 10:01 am
This is my glass Thermo-jam. Daytime vid so you can see the setup. It was also one of the longest runs ive had yet.
GlassTJ_daytime.mp4
(1.92 MiB) Downloaded 187 times
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 10:03 am
Nightime view of the glass Therm-jam. Note the shape of the flame.
GlassTJ_Vertical.mp4
(1.61 MiB) Downloaded 194 times
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 10:05 am
This one shows how the flame 'Dances ' in shaft like shape directly below the intake ports.
GlassTJ_FlameShaft.mp4
(1.76 MiB) Downloaded 180 times
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 10:15 am
For comparison this vid is the same jar type, but run as a normal jamjar with just a single 11mm hole in the lid. The jar broke about half a second after the video finishes.
16floz.mp4
(1.85 MiB) Downloaded 172 times
jamjarjim
Post by jamjarjim » Fri Sep 05, 2014 10:19 am
These are some photo's of the jar lids i've been using
These first two show the lid of the standard jamjar
The second two show the lid from the Glass Thermo-jet.
Fileeraus
Post by Fileeraus » Tue Aug 02, 2016 7:12 pm
I hope if you don't mind about my thermojam, I just built it. I am surprised how energic this is! I've never had a jam jar glow red, and this glows red even without any cooling. https://www.youtube.com/watch?v=fK6d3cl6aT4
