M500 build log
astroadrian99
Re: M500 build log
Post by astroadrian99 » Sat May 24, 2014 6:31 pm
Just wondering, do you happen to have any plans on this? It just looks awesome.
Re: M500 build log
Post by PyroJoe » Fri May 30, 2014 8:34 pm
Svarthalet Racing found one that didn't break. The local Seismographs should be able to tell you the frequency. :wink: It's been good watching this come together. be safe, and use chain.
Re: M500 build log
Post by Mark » Sat May 31, 2014 2:40 am
That's a labor of love.
Re: M500 build log
Post by metiz » Sun Jun 01, 2014 6:37 pm
PyroJoe wrote:Svarthalet Racing found one that didn't break.
I contacted them before, They said they used a hunting scale. The Netherlands isn't realy a hunting country so they're kinda hard to find. On the positive side, I just found out that an uncle has a nice beefy generater I can borrow whenever I like! one less hurdle.
Re: M500 build log
Post by PyroJoe » Mon Jun 02, 2014 1:23 pm
Amazon has a hunting scale not sure were you could find one locally, maybe a restaurant supply store:
http://www.amazon.com/Buffalo-Outdoor-H ... B00C1WRFHG
Re: M500 build log
Post by metiz » Mon Jun 02, 2014 3:17 pm
Thanks, but the Amazon one can't be shipped to the Netherlands, apparently. Because reasons.
googling "hunting scale" or the Dutch translation doesn't realy yield any usefull hits. are there synonyms I can use?
Re: M500 build log
Post by Mark » Mon Jun 02, 2014 8:43 pm
I had a Chatillion "spring" or "hanging" fish scale that went up to 50 pounds, not that you would probably want that particular scale. Maybe try veerbalans or opknoping schaal if that's the translation. Going out on a limb here using Google translation.
http://www.stripersonline.com/t/680503/ ... scale-0-60
http://www.globalindustrial.com/g/mater ... ing-scales
Re: M500 build log
Post by metiz » Wed Jun 11, 2014 11:04 am
Just got this cranescale in the mail. Pretty cool. Will measure in pounds, kg and Newton. 100 gram resolution and 300kg capacity
zono
Re: M500 build log
Post by zono » Thu Jun 12, 2014 11:21 am
I am afraid, 300 kg will not last ;-)
___________________________
zono - the thruster buster
Re: M500 build log
Post by metiz » Sat Jul 26, 2014 10:23 pm
I tested the engine and It runs. That's the good news.
We tested the engine for a good part of the afternoon but had no luck. lots of growling and close runs but no lock-in. The sound wasn't as bad as I though so I tried manually starting by just holding the leafblower by hand and using only LPG. After a bit of fiddling with the Rosscojector, it finally started, loud as *, even stationairy, but the rosscojector decided to come loose and burn my arms and neck. borderline 2nd degree burns all over (but not quite luckily) rather painfull.
Anyway, redesign the injectors, rethink the "start from a distance" and try again in a couple of weeks probably
Here's the video, Just the "good" part. I'll make a longer video some other time with the start-up bangs and huge smokeplumes and shit
www.youtube.com/watch?v=XKjN0Bw61e8&feature=youtu.be
Re: M500 build log
Post by Mark » Mon Jul 28, 2014 1:03 am
I'm glad it ran, that was a lot of work you put into it. Time is the only thing I've found to relieve burns.
Re: M500 build log
Post by tufty » Mon Jul 28, 2014 7:22 am
Aw, man, that's an awesome noise it made just before it decided to go all "burninate".
Burns are bad news. Hope they repair nicely.
Kool
Re: M500 build log
Post by Kool » Mon Jul 28, 2014 8:41 am
Ouch, burns are nasty specially with this hot summer days. I wish it heals well for you.
Besides that it's looking you're nearly there :D
Re: M500 build log
Post by metiz » Mon Jul 28, 2014 11:42 am
Thanks guys! I'll be testing again in a week or 2 I think
zono
Re: M500 build log
Post by zono » Tue Jul 29, 2014 7:03 pm
uuuuaaaaaahhh !!!
I am amazed !!! what a beast...
well done metiz, and get well soon !
