competition
ganuganu
Re: competition
Post by ganuganu » Thu Jun 23, 2011 2:17 am
thank you joe,but i have a question here what should be the angle between the three intakes..hello metiz can you help me out with this(intake design)..
Re: competition
Post by metiz » Thu Jun 23, 2011 10:05 am
75 degrees works for me but it isn't set in stone. try anything between 75 and 120 degrees
*edit* didn't read correctly: if you have 3 intakes then go for 120 degree sepperation
ganuganu
Re: competition
Post by ganuganu » Thu Jun 23, 2011 12:53 pm
metiz wrote:75 degrees works for me but it isn't set in stone. try anything between 75 and 120 degrees
take a look at the pic,have i done it correctly..And any idea how much thrust it will give..
Re: competition
Post by metiz » Thu Jun 23, 2011 1:34 pm
what is the angle of the intake, is the length measured from the centreline, is the length measured to the end of the flare or to the end of the intake, what is the flare length?
ganuganu
Re: competition
Post by ganuganu » Thu Jun 23, 2011 2:05 pm
angle of the intake is 20 degree,length is measured from centreline..Yes length is measured to the end of the flare..flare length is 0.7cm..
Re: competition
Post by PyroJoe » Thu Jun 23, 2011 3:03 pm
FWIW I calculate the minimum intake length near 14cm. Of course my intakes are typically short, so take liberty, go longer and trim to a suitable length.
Re: competition
Post by metiz » Thu Jun 23, 2011 4:56 pm
I realy don't like this style engine, it looks all wrong :P Anyway, your intakes look about right. Reduce them to 16.05cm
(6.98 KiB) Downloaded 56 times
Re: competition
Post by PyroJoe » Thu Jun 23, 2011 8:27 pm
Its the new fugly stick. :P
