my first designs
my first designs
these are my first two design guys.thanks for pyrojoe for posting the topic "receipe for beginners",it was really helpful..BY reading it i have made two designs.here they are..first i will build the smaller engine designed by me(t2 in shown fig)..the after which i will build the larger one(t1 shown in fig)..please help me iam a beginner..
Re: my first designs
why no reply from anyone
Just been a little busy.
The Recipe would produce something like this for a single body.
Using 2 blended bodies has it looking more like a typical thermo jet.
any idea how much thrust this engine will produce,its learning time for me please help me..i want 30 pounds of thrust will this be enough..
Hello Ganuganu
From an 5 inch dia. engine it must be possible to get 30 pounds of thrust I think. It looks like a scale-down of Metiz his design and that one was around 40 lbs. Try it and you will know
But I hope you will know after this time on the forum good fueling is very very important.
Why are you not going for one intake?
Why not chosing for a straight exhaust?
If you could answer those questions, I think you're more on the way in your learning-process than scaling other designs.
(Not trying to blame you, I've also some scaled drawings, which I tried to run In Nudis and Uflow, but that didn't work well for me )
yes thats the scaled down version..and my answer for your questions now..i WILL say whatever i know..if we use multiple intakes there WILL be more proper mixing of air fuel mixture..more than straight pipes these conical types produces more thrust..i think this WILL be the answer..
I am trying to build a valveless...I have been using PyroJoe's recipes (Thanks soo much!) I like the valveless more than the valved ones. I don't really have much of an Idea of what to do for anything (Fuel systems, mounting, etc.) all I know is that you can use propane and brake line for the fuel and light it with a torch. also, what is the thickness of the steel, and is it black, galvanized or stainless? I really like this design of a thermo-type, and with 2 intakes facing backward. any help/advice would be much appriceated....thanks.
