augmenter for M40
Re: augmenter for M40
Post by PyroJoe » Fri May 06, 2011 5:39 pm
The Thunderchine augmentors would need to be smaller. If possible print the plans at 74.6%
If not an option then try to build near the standard augmentor formula seen below. Bashing and weld what you have available as Jutte recommended.
Post by metiz » Fri May 06, 2011 8:56 pm
How about this. Looks like they could be a bit longer?
ganuganu
Post by ganuganu » Sat May 07, 2011 2:48 am
by using the standard augmenter formula i get the following values..
delta= 2*5= 10cm
D=2.6*5= 13cm
L=10*5= 50cm
R= 0.25*13= 3.25cm
what do you think about this..
Post by PyroJoe » Sat May 07, 2011 3:39 am
Ganuganu the math looks good, metiz, i agree that looks a little short for my eye. It is important to have a smooth interior seam between the flare and the augmentor body. Looks like the flare could be slightly wider, but what you have there is a good place to start.
Post by metiz » Sat May 07, 2011 10:44 am
The engine geometry is limiting what I can do with these augmenters unless I make then ridiculously hard to build. Ill lengthen the augmenters and add some fat to the flares. Asume they're hammered into a nice belmouth instead of a hard cone, don't want to make those things in sketchup :P
ganuganu
Post by ganuganu » Sat May 07, 2011 12:22 pm
here is the drawing of the calculated dimensions..is it k to use it in the intake side..
Post by metiz » Sat May 07, 2011 5:57 pm
Look at your engine - you'll never be able to fit those
Post by PyroJoe » Sat May 07, 2011 7:22 pm
wow, those dimensions are on the large size, best to wait and see what metiz formulates.
Post by metiz » Sat May 07, 2011 10:29 pm
dual augmenters don't realy work. I'm trying to fix up a single augmenter for both intakes now. Kinda hard, stand by.
ace_fedde
Post by ace_fedde » Thu Nov 10, 2011 11:19 am
'Knew I had them. 'Been looking a long long time for 'em. Found 'em:
AUGMENTOR.pdf
(29.88 KiB) Downloaded 311 times
NASA TM-2005-213854[1].pdf
(1.58 MiB) Downloaded 319 times
Rob Miller AIAA-2009-1063[1].pdf
(931.47 KiB) Downloaded 337 times
I will post a link in the plans section.
Fedde
Kool
Post by Kool » Thu Nov 10, 2011 9:45 pm
Dankjewel Fedde.
Thank you, reading english pulsejet reports is really good for maintaining the knowledge of the english language :)
