liquefied petroleum gas
ganuganu
Post by ganuganu » Mon Feb 07, 2011 12:13 pm
can i use this LPG as fuel for big pulsejet engines which produces 42 pounds of thrust....will LPG cylinder be able to supply me appropriate pressure.. :?: :?: :?: :?: :?:
Re: liquefied petroleum gas
Post by metiz » Mon Feb 07, 2011 12:49 pm
Just asked around, LPG is pretty much the same as propane. I had to know for sure. But yes, you can use it.
ganuganu
Post by ganuganu » Mon Feb 07, 2011 1:43 pm
metiz wrote:Just asked around, LPG is pretty much the same as propane. I had to know for sure. But yes, you can use it.
thank you sir,just now i browsed in the web as "LPG vs propane" they say that both are used for cooking purpose.lpg is also known as propane....
