The M25
Re: The M25
Post by metiz » Tue Aug 10, 2010 4:30 pm
Re: The M25
Post by PyroJoe » Tue Aug 10, 2010 5:51 pm
Thanks for building and sharing,
Good stuff!
turbinepower
Re: The M25
Post by turbinepower » Wed Dec 07, 2011 9:36 pm
hello Metiz good work,i am a newcomer by pulse jet engines.I am very interessd to come in touch with you.I looking for one 5 kg thrust pulse jet,maby you can help.
thanks very much
Turbinepower
kevin lee
Re: The M25
Post by kevin lee » Mon Dec 12, 2011 4:31 pm
Hey turbinepower these links maybe of use. These are designs I have that should be good for us newbies
http://www.popularmechanics.com/home/ho ... -pulse-jet
One of Larry' designs
And
http://www.pulsejetengines.com/freepulsejetplans/
Beck tech designs iirc
3lb thermojet jet
Advanced fwe
12lb Chinese
Maybe someone can confirm whether these are legit for beginners?
kevin lee
Re: The M25
Post by kevin lee » Mon Dec 12, 2011 4:33 pm
I have read through this thread, nice pj but looks like I would need some experience before jumping in :)
kevin lee
Re: The M25
Post by kevin lee » Fri Jan 13, 2012 10:21 am
Hi Metiz, I noticed you have posted in the last day or 2. Hope you don't mind me bothering you about this engine!
Have you weighed this engine and what gauge stainless steel is it constructed from?
Also are you able to release some plans too me?
Thanks
Kevin
Re: The M25
Post by metiz » Fri Jan 13, 2012 12:54 pm
The plans are freely available, just can't find them back on the forum...look for the attachement in this post. The engine has been constructed from 1mm 304 stainless steel. Never realy weighed the engine but I think it's around 3 pounds. You can round off the dimensions to 1 digit behind the period e.g., 39.356 = 39.4
Make sure you follow the plans as close as possible.
If you're having trouble with some of the layouts (like with the choke cone and the hole alignment) let me know.
kevin lee
Re: The M25
Post by kevin lee » Sat Jan 14, 2012 2:53 pm
Bedankt Metiz
Iam very greatful of your help, and iam sure ill be asking more questions regarding this design.
Infact do you have any thing to add regarding the use of petrol/gasoline? I have ideas of making some kind of stupid rc plane and flying this engine :D
Kev
ps. i have had a little search and been unable to find where the plans were posted orignally but i should be able to get on ok with the above drawing.
Re: The M25
Post by metiz » Sat Jan 14, 2012 4:22 pm
If I knew how to fuel this engine efficiently with liquid fuel I'd be flying it myself. It's very hard to do. I have some ideas and a somewhat promising prototype but all testing has been put on hold indefinitely.
kevin lee
Re: The M25
Post by kevin lee » Sat Jan 14, 2012 8:54 pm
Not a problem, i understand!
i think i will build an m25 or m40 for fun, and build a valved atomjet ect for flight, i can always go back to the m25 if i figure out how to liquid fuel it.
or maybe i should make that the task, a liquid fuel solution so that it can be flown!!
too be honest i dont think i have enough experience at this moment. maybe in a year or two ill have some ideas :)
Re: The M25
Post by metiz » Thu Oct 30, 2014 8:09 pm
I was messing around with a liquid fueled M25 a couple of years back. I never realy properly tested it but I did build a single intake version of the engine so here are the plans if anyone's interested (all dimensions internal)
brownms
Re: The M25
Post by brownms » Thu Oct 30, 2014 9:39 pm
Thank you very much.
Regards
Re: The M25
Post by metiz » Thu Nov 13, 2014 7:17 pm
Anular M25. Lets see if this is going to work.
