Re: More free plans: 40 pound Thermojet
I'm working on a version of this engine with the intakes seperated 75 degrees instead of 180. The theory is that the opposing intakes create some unwanted effects in the engine making it a non or VERY hard starter. The 75 degree version should solve these problems, hopefully.
I do not have the tools to replace the intakes on my original version without messing it up or exeeding margins so I'm building a new one. Barry, your construction and welding skills are better then mine. If and when I get this version to work I'll release the plans for the new choke cone. If you want, you can then replace your original cone with the new one.
Below is a picture, courtesy of GRIM, that shows the new engine configuration. GRIM also supplied the layout for the new choke cone.
Hard too say,but there is something wrong with the plan.On 1 intake,mine running good.
I think also that the intakes are too big.
But you may cut 1 intake & close the hole with a piece sheetmetal.Just for testing it will be ok.
LOUD PIPES - SAVE LIVES
With one intake, the engine won't breath as well as with 2 so it will lose a lot of power. Furthermore, the tailpipe will be overexpanded with 1 intake making this engine worse still. The models suggest that this engine should run just fine with those intakes so I'm hoping it's a positioning problem (see picture on top of this page) I might be able to have the new version up and running this saturday. Time will tell
i know this is kinda of a "im-new-question", but, do you HAVE TO use injectors at the intakes? or could you leave the intakes free and insert an injector trough the CC? i've seen this work in lockwood-hiller's, so is there a chance this could work on th M40? I plan to build one myself, so I'd like to gather all possible info first.
The injectors do not necessarily have to go through the intakes. This is done 99% of the time because it's the easiest solution. You could feed straight into the cc but you will need some serious atomizing nozzles. I have no experience with that kind of fueling and even if I did, I can not guarantee that it will work.
If you plan on building this engine, wait until I have finished building and testing the new modifications (you have been following this thread right?) The engine as it is now appears to be a no- or ridiculously hard starter. I hope to fix this problem by repositioning the intakes
I had a crazy idea, tell me if it could work hehe...
remember the pressure-jet fuel-line-heater with a 0.070' noozle diameter? could that somehow work, or would that be TOO MUCH propane for the air coming in? and could extra intakes to fix that air ratio problem be added?
I plan to build a valveless for my semester proyect at university...
also, do you have a valveless plan for a big, powerful, easy (or better, self-) starting jet that has been proved succesful?
Well I'm not going to lie: I'd rely like to see you build this engine - after the mods et all, but if you want an even more powerfull engine, try the thunderchine. As for the pressure jet injector, that won't work in a pulse-jet. to fast.
great, where do I find plans for the thunderchine? is it easystarting?
and oh's, would have been fun to have a supersonic injector in a pulse hahaha
well crap
you can find the plans on either the "calculating top speed on ice" topic or the thunderchine topic. be aware that there are multiple versions of this engine.
The new version is comming along nicely. All the cones are rolled and welded (except for the rectifier: managed to roll that one in the wrong direction) Just need to weld the lot up and it's done. Still on track for saturday testing.
Just need to weld this thing up, put the front dome on, inectors/ sparkplug and things like that and it's done
Nice work, Metiz
Are you planning to put an augmentor on it?
