micro LH "WASP"
NO_LIMITS
micro LH "WASP"
Post by NO_LIMITS » Tue Sep 29, 2009 7:17 am
HI, first, sorry for my english
this micro match box sized LH engine was thin layer moulded (from "stainless steel") not welded
Image Image
its ultralight and all measurements are kept, the inlet and exhoust pipe on pictures abowe arent cut to its orginal size yet
I didnt run it yet, hope it will start right up
Re: micro LH "WASP"
Post by metiz » Tue Sep 29, 2009 7:43 am
Awesome! I hope it works. You'll have to run it on acetylene though
Re: micro LH "WASP"
Post by PyroJoe » Thu Oct 01, 2009 6:07 pm
That is tiny! How does the thin layer moulding process work?
NO_LIMITS
Re: micro LH "WASP"
Post by NO_LIMITS » Fri Oct 02, 2009 2:42 pm
Hi, this is quite simple, designed model is transformed to its form, then the form is filled with hot wax and quickly get rid of the excess wax, you will have thin layer model from wax, than add some holes, and wax sticks, fill the model with high temp. moulding clay, than heat the form in oven to get rid of the wax, than melt some stainless steel (you will need some hydrogen oxygen torch), mould the model, get rid of the clay, and its done. It will be much more simple when I will have the designed model printed on 3D printer in wax.
Ghrey
Re: micro LH "WASP"
Post by Ghrey » Sat Oct 10, 2009 8:07 am
Lost Wax casting.
A most versatile method, I have used it for jewelry, never quite thought of using it for jets. Thanks for the eye opener.
Life still complicated.
