Yet another pulseramjet
krzys Mnich
Post by krzys Mnich » Tue Sep 22, 2009 5:10 pm
Hi,
the idea is not new, but the design looks pretty elegant.
First the theory: rear intake pulsejets, like Lockwood or Chinese, work well at low speed, but at high speed they become worse, and at supersonic speed, I guess, they don't work at all. It's not easy to build a valveless, that work well in a wide range of speed. Instead, you can feed the pulsejet with air slowed and compressed in a ramjet. Just put a pulsejet (or its intake and exhaust only) inside the ramjet.
The capped tube valveless fits perfectly to the ramjet, doesn't it?
regards
krzys
Ghrey
Re: Yet another pulseramjet
Post by Ghrey » Sat Oct 10, 2009 10:01 am
When you find a way to make that Annular Valveless run well and reliably, you will have done very well, and let me know how you did it I am still trying. Off hand the other complication would be that you will need some very heat resistant material to withstand the heat load.
I am not saying it is impossible just that there are these considerations.....
Life still complicated.
