Ha ha, I hope that lawn don´t belong to anyone that cares about it! I did the same thing on my mother´s lawn a couple of years ago, she didn´t say anything though. Just the regular head-shaking...
You are on the right track with the engine, it sure gets enough fuel from the looks of the flames.
Finally trying that Thunderchine...
Re: Finally trying that Thunderchine...
No, That will do fine , thanks for posting it , The grass , , well it will grow back, sort of, given time ,zohrke wrote:GRIM: If this version is not enough for your sound analysis or whatever you are up to with the audio, contact me. I can then send you a zip file or such with fresh juicy uncompressed DV audio.
HI,
i'm kiran and i'm new to pulsejets and to the forum..
i was very much impressed by the thunderchine and took it up for fabrication.. but now when it comes for testing it simply wont start but gives a howling sound and thats it... could you please help me in starting it up...?
here are some of the specifications...
fuel injectors: 2x1x7mm pseudo roscojector shaped at 100mm from the flare, compressed air for start up and manual ignition..
i dont know where i am going wrong... plz help me...
i've uploaded a video regarding the same in the link below.
http://www.youtube.com/user/bmkiran88?f ... scdXlU8E2Y
¡Aviso!
Greetings.
No maintenance for the original Thunderchine plans thread, or any subsequent threads, will be forthcoming.
As I am no longer a member or a participant in this forum, existing builds will be supported via email only.
If you have not already received a valid email address from me, one will be forwarded to you in due course.
Prospective builders are advised to look elsewhere for plans. If you are NOT a novice builder, I recommend
you search for pulsejet plans from that most excellent, mild-mannered of active, on-forum builders, Metiz.
M.
Greetings.
M.
avast!
Cap'n M.
avast!
Cap'n M.
