VivL Nudis maybe some day, but for now, working with metal and fuel.
IMHO the heat generated is only partially used for acoustic generation. Most is wasted
OTOH waste heat can be used in many ways. I can think of quite a few off the top of my head. Wrap a coil of 5/16" tube about 25 feet long around the CC and insulate around that with a vermiculite inside a sheet metal jacket. Apply water pressure at one end from a garden hose and probably generate enough steam to run a 1 HP flash steam engine. Not that I'm interested in doing that. I suppose you could also inject preheated water and gain thrust in a thrust engine, or one used as a gas flow generator for a turbine.
You can also get electricity direct from heat using a thermoelectric Peltier effect device, which uses bismuth teluride to generate a potential.
Or wrap single half loops of fine SS tubing around the CC and feed these into the displacer chamber of a hot air engine.
Or investigate differential cooling on the tailpipe to possiblt boost pulse amplitude via hot air engine effects. The last is the only one above of interest to me since I'm shooting for a pure system without additional "engines", but anyway, there is lots to investigate about not only reducing waste heat, but using it.
But again, back to nuts and bolts. I got the reducer, here's what I have so far for a propane feed.
PyroJoe, I'm getting closer to a bigger draft engine. Everything I hear about it seems like what I need. Of course that's what you and Grim suggested from the start. But I'm glad I got practice, and understanding (and a little more confidence) with the other engines.
By the way, I did run the big snorkeler a few times today -- conditions were a little better even though it poured rain last night. I was able to try my longer snorkel -- got the loud BRAAAAT at first, then whittled that height down in two .25" steps, and got what seems like pretty good running, considering the still too high humidity. I need to water cool it better now if I want sustained runs on methanol. I really like the sound of that engine. Wish I could get it to run for a long time. I'm sure I will, if only because the weather will eventually get better.
I also got your J pipe draft running for extended periods on methanol, though not consistently locked in. Lots of in-between gurgles and rumbles but the flame didn't go out so I could try different positions. It seemed to like an extreme forward angle on mine -- unlike yours, less than 45 deg. from horizontal. I got some long runs that way (for me). I also tried larger and smaller holes on my second pipe cap, but the stock 5/16th in. hole ruled. Mine also seemed to like a bit of fuel -- ran better that way than when low on meth.
Richard Feynman
