V8 thermojet
ace_fedde
V8 thermojet
Post by ace_fedde » Mon Jun 01, 2009 6:10 pm
Wow, I love this sound:
http://www.youtube.com/watch?v=P-a577HkRfA
I had to know:
-----Original Message-----
To: rons22@
Sent: Sun, 31 May 2009 6:33 am
Subject: thermojet
Hi
I would very much to duplicate the idle running of your thermojet. Could you please give me the details about fueling and dimensions?
This is the first pulse jet that I hear running idle like this.
Did you ever visit the forum on pulse-jets.com? You could also become a member (if you aren't already) and discuss the details there, people will be very thankful!!
Fedde
To: ace_fedde@
Subject: Re: thermojet
Date: Mon, 1 Jun 2009 12:30:53 -0400
Fedde,
I use a 5 gal Propane cylinder with a needle valve to supply the gas. The jets in the supply nozzles limit the full open amount supplied. The jet is small - 21" but, it's the needle valve supply and the tuning at low throttle that lets it sustain and rumble with out much thrust when the gas flow is low.
My injectors are 3/16" steel brake line that has been welded shut and drilled #70. They are inserted into the inlets about 1". The inlet tubes are 5/8" dia. and 3 1/4" long.
The hole is into the welded end so the jet directs itself into the inlet.
Ron
Re: V8 thermojet
Post by Eric » Tue Jun 02, 2009 2:53 am
Here is a narrated overview of one of my leak free engines setup and starting, which is hard to confuse with the spot welded engines after you see one run.
http://www.youtube.com/watch?v=wDiLAWUyzp4
ace_fedde
Re: V8 thermojet
Post by ace_fedde » Tue Jun 02, 2009 6:12 am
Eric,
Shameless advertisement, haha :lol: :lol:
Now, I already have my own, fully welded, thermojet. I posted the above because of the idle running of that thermojet. It runs idle like a V8 :D :D
I want to make mine also run idle like that.
Fedde
Re: V8 thermojet
Post by Eric » Tue Jun 02, 2009 6:48 am
Ah I guess I should have explained that the "V8" noise isnt actual running, its a gurgling noise you can get from sticking a forced injection flame in just about any shape tube.
Re: V8 thermojet
Post by metiz » Tue Jun 02, 2009 10:22 am
ace_fedde wrote: Now, I already have my own, fully welded, thermojet.
*cleans nails, looks smug* :P
you might be able to get the growl you're after if you replace the straight injectors with nicely made Rossco's. position them close to the flare.
ace_fedde
Re: V8 thermojet
Post by ace_fedde » Tue Jun 02, 2009 1:10 pm
Another shameless advertisement :lol: :lol: :lol:
Yes, my thermojet is a Metiz' thermonese! :D
Fedde
ace_fedde
Re: V8 thermojet
Post by ace_fedde » Wed Jun 03, 2009 11:06 am
Eric wrote:Ah I guess I should have explained that the "V8" noise isnt actual running, its a gurgling noise you can get from sticking a forced injection flame in just about any shape tube.
Eric, Metiz,
Thanks for the advises! Will work for me! :D
Fedde
