Awesome video, mate! Despite the compression imposed by Youtube, the acoustic spectrum is excellent.Johansson wrote: As you can see we had a very successful first test.
Motor resonance frequency (via f1-f6 series weighted average) is 163.3-163.5 Hz (excellent agreement);
with peak acoustic power at f3 (spot on), followed by f4, f2, f5, f6 and f1 (yes, fundamental is weakest).
Music to mine ears!
Don't say we didn't warn you. LOL.Johansson wrote: After a couple of attempts I crimped the injectors down to a 1x7mm slot.
And this one looks so good with its sexy black coating. Btw., what is that? Has a greasy sheen... WD-40?Johansson wrote: I consider this engine as a test engine and will most likely build a stainless one once this one runs as it should.
Good to know. This will remain true after you add the ejectors; the ejectors are canted slightly upwards.Johansson wrote: Another good thing is that the tail won't lift from the rear cradle mount.
Most impressive. Even the trees looked to be shaking. That's more air than most politicians can muster!Johansson wrote:Nice echo. (from video)
I will sleep a very happy sleep today! Congratulations, mate!
Cheers,
M.
