Johansson wrote:
The remaining question is how I can estimate the air resistance and
how it changes with speed, since it will be the main limiting factor.
Spot on, Anders.
I decided to run the preliminary calculations in my head, ie., no paper, no pencil, no slide rule, just
the "noodle". Once I had worked through Anders problem from two (2) different directions, I used a
calculator (
non-graphing
, thank you!) to verify my "noodle-numbers"
. I am pleased to report a result:
Unless our Mr. Johansson goes out of his way to squelch any aerodynamic
"slipperiness" in his
kick,
the
final determinate of Anders' top speed over 2000 meters will be when
he backs off the throttle.
Let's call this speed the
"brown trousers limit".
Anders
: I don't think 200 kph is unrealistic
, but I will run detailed calculations once I get all the data.
If the
kick hits 200 kph
, Thunderchine's
output will approximate
20 kW (requires careful modeling).
Cheers,
M.
Code: Select all
> invoke.rule("Will someone please think of the children!") | apply.edit(this_post);
