Re: "Thunderchine" 55 lb thrust pulsejet plans
Posted: Wed Feb 18, 2009 4:43 pm
Assez. Je suis d'accord!
M.
M.
"Home-made Jet Forum"
http://www.pulse-jets.com/phpbb3/
yesterday, Ghrey wrote: And now from left field...
What is the maximum allowable radius for each joint?
Picture the jet made from a contiguous piece of material if that helps.
Not at all; we were simply ignoring you. While I am as big a fan as anyone of möbius strips,today, Ghrey wrote: Was I some how unclear?
And I had such high hopes for you; ...all the cones in Thunderchine save two are eccentric cones.GRIM wrote: I might as well come clean, I screwed up the big cone, forgot to put the end angle on it,
my fault, stubborn, plotted the cones "my way"...
You saved yourself here, mate! I wish I could have you stay after class and write that out 100 times!GRIM wrote:THE PDF IS GOOD
LOL. Well... The answer to this question will decide my answer: have you already rolled the ejectors?GRIM wrote:I really dont want to make another big cone...
If you want to use the cone that you have, then kiss the ejectors goodbye: the whole point of RosscoIf "no", then my answer is "yes": you may use the concentric super cone.
If "yes", then my answer is "no": you must make a new spec. super cone.
Wow. The templates were sized for 0.8 mm, so you're way out there. Rossco will check to see whereGRIM wrote: One other not to drawing detail, is the thickness of the material, I purchased 1.5 mm,
when I got it home and started rolling, I measured it and found it to be 1.8 mm thick.
Have yet to see this one! IMDB rated it 7.6/10. The link... http://www.imdb.com/title/tt0119396/ .GRIM wrote:No kill Bill , but Jackie Brown might put in an appearance sometime.
Apologies, to both of you , The main reason for my folly was an ignorance on my part re, PDF ,milisavljevic wrote:Rossco wanted to reply here, but me thinks he needs to chill for a while longer. Maybe a day, or two.
( I needed a few hours myself... )
milisavljevic wrote:And I had such high hopes for you; ...all the cones in Thunderchine save two are eccentric cones.
We have to ask ourselves why we even bothered to draw the patterns if no one is going to use them.
NO I have not cut or rolled the ejectors , So I guess it will be a concentric "unadorned core" ,milisavljevic wrote:If "no", then my answer is "yes": you may use the concentric super cone.
milisavljevic wrote:Wow. The templates were sized for 0.8 mm, so you're way out there. Rossco will check to see where
that puts you wrt. internal diameters, and then I will model how this affects peformance. No worries!
That's cool. And at least you can get thrust readings independent of the ejectors. Obviously, it does notGRIM wrote:NO I have not cut or rolled the ejectors, So I guess it will be a concentric "unadorned core".
Cool!GRIM wrote:No worries there, I took into account the material thickness, the cones are all within spec...
Oh noes! Say it ain't so, Joe! ...the real world strikes again!GRIM wrote:But progress will likely be slower, my wife returned home last night...
Poor Genius! Safari Blockflash works tooM.
PS: I just found out that I can adblock your sig. Hallelujah!
Thanks for the tip, Viv! ...Oops! Another annoying sig bites the etheric dust.Viv wrote:Poor Genius! Safari Blockflash works too.
