Oh no no.. INSIDE the diffuser is super smooth, what I meant is that the cut is not in a straightline and it goes up and down. I don't have a clamp so I drew a line (which is not that straight) freehand and saw according to it. When placed cut-side down, it's still generally straight but it won't be a perfect fit like the machined-cut.larry cottrill wrote:Don't worry about following the exact specs -- it was all guesswork to begin with, anyway. Roughness and/or bumpiness inside the diffuser could be a problem, but I wouldn't be bothered by it until you've tried it. If the diffuser action is poor, you'll probably see some rough combustion, or maybe combustion "leaking" forward into the diffuser section on that side or something. But, if not too severe, I'll bet it will still work fairly well for you.
Fast reply ^.^larry cottrill wrote:I like the diffuser except for the rolled region at the front. Remove that part completely, and hammer the edge outward to form a SMALL flared intake -- just a few mm long x a few mm outward from the basic curve of the "cone". True, a flared inlet will take away a little of the overall diffuser ratio, but it will help smooth out the flow of the intake air going in, and will also strengthen the front edge. Otherwise, looks good, I think.
One thing you might invest in is a Dremel grinder. That makes an easy job of something like this: You just grind away that innermost rolled corner, working your way gradually around the circumference. Before you know it, Voila! The unwanted piece just falls off. And if you've been careful, you end up with a perfect finished edge -- no buckling, distortion, or any such.fterh wrote:Omg.. more sawing?! You gotta be kidding :( :( :(
Okay .. I'll saw that part away. And will my flameholder work? I think I'll weld it in this manner:
] (intake from the left)
same as your design. If it doesn't work, then good luck to me trying to pry the whole thing apart.
And for the flared intake, maybe if it's too hard I won't do it first, after I run it for the first time maybe I'll try flare it to improve performance.
And what's the diff between axial and centrifugal fan? And is this:larry cottrill wrote:Any fan that provides enough flow at a reasonably high speed should work. Axial fans will have a lot of torque (twist) to the output flow, so on these you should provide a reasonably long "flow straightener", even if just crudely put together from a bundle of tubing scraps. A centrifugal fan probably won't have much torque, but can suffer from somewhat uneven stream velocities, which could be corrected just by providing a long, slightly converging "nozzle" (which is what makes the typical leaf blower such a nice choice).
It is practically impossible to get any fan design to produce a perfectly laminar flow stream right out of the exit port; you always need to condition it to some degree.
Check out the delta fans.. their dB are crazy and their cfm is like, 150+? Those are PC fans too.. but they are crazy powerful.larry cottrill wrote:That's an axial fan - a fan that blows air parallel to its shaft axis. "Centrifugal fan" is an engineering term for what most people call a "blower", but also covers an "impeller" (like the little spinner inside a leaf blower). Either one can be made in a high volume and/or high speed form, but of course that requires a lot of power (big motor). The two types have VASTLY different operating characteristics, but that's not a problem for what you're doing.
The type you show will be too slow, unless it is a REALLY big one and you provide a long nozzle cone to radically speed up the flow stream. These cooling fans are actually designed for fairly slow air motion, because slowly moving air gives highly effective cooling and requires little power to run.
See if you can find something in a junk shop or some such. Either a leaf blower, shop vac, or some kind of industrial blower stripped from small equipment of some kind (a lot of them are used on equipment with gas burners). You'll never make it work unless you get something that moves a LOT of air at pretty high speed.
Another thing I thought of one time was mounting the engine on the outside of a car moving down the Interstate (driven by ANOTHER person!) while I provide fuel and ignition and observe it through the side window. I abandoned this as basically impractical, however.
Not so. A nozzle is the opposite of a diffuser, in terms of its action on the air flow. Air enters a diffuser at one speed and exits at a lower speed -- but its static pressure is elevated. A nozzle, on the other hand, is driven by pressure -- the air enters at a certain speed and pressure but exits at a higher speed at reduced pressure. The pressure difference across the nozzle (end to end) is the driving force; the effect is gas acceleration. This why we use a diffuser at the front end of our ramjet (to obtain stable combustion at a significantly elevated pressure) and a nozzle at the rear end (to maximize exit velocity, using the static pressure AND taking advantage of the gas expansion from heat of combustion).fterh wrote:And why will a long nozzle cone speed up the flow stream? I mean the long cone just provide more friction for the stream to "rub against" while moving down only right?
