Post
by larry cottrill » Mon Jan 12, 2009 3:09 pm
Joe -
First of all, great work! I really like the folded one.
Now, something I'd like you to try sometime: It has occurred to me that one of the problems with the typical FWE geometry is that there is a "dead spot" out in front of the intake transition that is mostly untouched by vortexing during the intake phase; and, possibly another corresponding spot down in the lower front (just because the gust can only go so far before it's dissipated in vortexing, etc.). So, try this, preferably using an FWE cone (the original long, gentle slope) with a Lady Anne style intake and transition 'fairing':
Right in front of the transition, cut off the front of the cone and replace it with a cylindrical wall (length same as cone segment removed) similar to what you've done recently. Then, smash the front edge of the cylinder down from the top and bottom fairly radically so the front of the chamber is strongly "duckbilled". I would say, roughly, squash the top and bottom together to half the circular diameter. Finally, weld on a quasi-elliptical front plate or "dome" to match the squashed oval shape. So, you should end up with a flattened area centered on the intake CL (and opposite), with slightly bulged "cheeks" on each side. This will reduce the chamber volume somewhat, so it won't tune quite the same as the original FWE chamber, of course.
I'd just like to see that tried, and see what can be observed from the heating of that kind of front end. What do you think?
- L Cottrill
