Thrust Augmentor Calculation Help
grant_gibson45
Post by grant_gibson45 » Sun Mar 02, 2008 7:46 pm
Hi,
I am new to the forum, although I have read many of the posts on here, and I know the subject of thrust augmentors comes up quite alot. However I need help fairly soon as I am writing up my university dissertation.
I have dimensions of a converging-diverging augmentor however I have 2 main questions.
How can I predict the thrust increase obtained from the augmentor because I tried working from first principles assuming 1-D isentropic flow, but I don't know the temperature of exhaust gas and velocity at exhaust exit to calculate mach no.
Secondly, I have devised an experiment to investigate the optimum distance from the exhaust tip to the throat of the augmentor and I am supposed to say that students would measure peak thrust against distance from exhaust tip to the throat of the augmentor. Then compare the results they got with a theoretical calculation. But can this "optimum" distance be calculated theoretically ? Is there in fact an optimum distance or am I missing something here.
I really hope someone can help as I am stuck at this point in my write up, because I obviously need to know the maximum thrust output to safely design a clamp.
Grant
Al Belli
Augmentors
Post by Al Belli » Sun Mar 02, 2008 9:30 pm
Hi,
See Bruno's post on thrust augmentors in the FAQ section of this site.
You can expect 1.8 to 2 times thrust augmentation.
Al Belli
