50 lbF 'Lady Astor' Not For Beginners
Yea Baby...love the stumpy one...and I did ask...but only for the LadyAstor....Go Girl....LOL...Mine arn't as pretty but.....Dam that is just the way things are we are on differnt tangents....All the best and you are way ahead of me for research I am into the fun part..
Hey i just built a set of expansion chambers for a fellow employee (bike racer TZR250)and he ended up in 2nd place in a regional race....on the east coast of Canada......power to the people.....
and pics of the witch....(sorry L)
Vern
Vern
- (471.42 KiB) Downloaded 187 times
- (352.42 KiB) Downloaded 218 times
Vern
bike race
Hahaha yeah i like that floor too! Congrats to your friend coming second on that regional race. Bike racing is really a sport for some really special individuals, I have nothing but admiration for their ability to turn off the brains "I could die now" protection systems and go for it. Kudos to him. That is a big ass woman no doubt about it Goodluck. Any Idea when you'll be able to fire her up?
astor
I should also say before you put your intakes on check the angle of entry isn't going to hit the front dome. I found that the intakes needed to be moved back considerably for the engines to even run now that the angle of the CC is so high. I basically just went along with a ruler to find a center point that was far enough back so it hits the bottom of the CC first. Perhaps some side on shots before cutting the hole?
Bigger But Fewer
Vern -Vermin wrote:Hi Larry.... et al
I have some 2" ID tubing available and i realize that the overall area will be slightly smaller than with the 3 intakes at 1.75.... (maybe the velocity will assist with mixing?) Do I have to change any of the dimensions as far as length of the stacks or positioning? Thanks
Vern
You will be at 87% of the design area, which is pretty close, really. I would guess you can go with the design length - if I'm wrong, you would just need to shorten them a little to bring it in.
Fuel Lines
Vern, you're going to need big fuel lines too - probably 3/8 inch OD tubing (maybe 8mm or so ID). You already know how to manifold them together nicely for well-distributed flow.
Also, be sure you have a good quick-cutoff valve where you can hit it quickly - once you achieve rich extinction for this babe, you are going to have a LOT of propane flowing!
Thanks Larry...
hopefully by the end of the wknd there will be photographic evidence......I am off to Alert (the end of dirt in northern Canada.... it's all water from there to Russia) for a week on Monday....... and I would like to have Her running before that, i will sketch the intakes for proper angle prior to fitting as James has suggested....it's all fun.
Vern
Vern
Vern
New Intakes (2)
Vern, that looks good to me. Let 'er rip!
Revised Thrash Mounts
I revised the thrash mount design, simplifying the connection to whatever you want to use to stabilize the rear end. Ideal thrash mounts will be two simple tubular struts at right angles to each other, bolted up to the engine in such a way that the engine can move longitudinally, both for vibration and thermal expansion. This new design (Rev 04) makes such a connection extremely easy. None of the basic dimensions of the engine have changed; just this mounting detail.
Yes, I WILL provide some large scale drawings of all the engine mounts. Stay tuned ...
- Lady Astor Rev 04 - the only change is the improved thrash mount design at the rear. Drawing Copyright 2007 Larry Cottrill
- (18.2 KiB) Downloaded 190 times
Well folks the first 2 attemps were not succesfull...I believe due to fueling issues. I only have 1/4" tubing available at this time and I have tried 2 injector styles and many depth positions, it will run but only with augmented air (dam loud).
There also may be a fuel flow issue with the LPG tank, the newer designs have a flow limiting valve in them and I may have to look at liquid withdrawl into an evaporator system of some type....sugestions would be apriciated. I will be away for a week so i will attempt any sugestions upon my return...Thanks Folks.
Pics of the product, amzingly light when built from 20G mild.
Vern
Vern
- (366.88 KiB) Downloaded 147 times
- (378.34 KiB) Downloaded 165 times
Vern
Great job Vern, that lady is going to howl !
Those 1/4 tubes do look kinda skinny dont they?
I am having similar problems with gas cylinders , but for other reasons.
There is another type of gas cylinder available, the ones they use on fork lift trucks (hysters) , they are designed for vapor or liquid extraction just by rotating them 180 degrees , they do however require a special fitting for the valve , and you get them re filled at the places where they re fuel gas powered vehicles , not sure how you are fixed on that one.
Im going to try to round one up this week
as for vaporizing the liquid gas , take a look at the jims 3lb thread , a small jacket around the cc would likely be all thats needed ,
you can probably get the stainless wool at the supermarket, its sold in little packs to clean kitchen pots and looks rather like swarf from a lathe
good luck
good luck
Fuel
There is nothing wrong with the two fuel injectors, that more then enough gas to get it running. I know your using double D's aren't you verninator?!
If it happens to have a flow limiter thats bad news, do your best to "Swap n go" for an older model.
I think you should go with some sliding intakes, I'm pretty much positive its just an intake tuning issue, if the intakes themselves aren't too far forward. I had envisioned having those intakes another 1/2 to full intake D back towards the choke. Perhaps I should have been more clear, the gas coming in through the intake tends to "Stick" to the front side or longest side of the elbow. There is more friction on it, and it will tend to roll out towards the CC dome considerably. I wouldn't be surprised if where they are now the incoming fuel/air mix is slamming right onto your cc dome.
I would play simply with your intakes lengths first. If that doesn't lock her in, move both intakes back and try again. I think you'd actually be able to get it running on one of those intakes, but since you have two, make the sliding intakes internal, they look quite large in the photo. There is plenty of fuel to get that engine at least running out of a 1/4 inch tube, just double D it so you get some better mixing. the DD doesn't restrict fuel flow at all. Keep going on it!
Forward Engine Mount Detail
Vern, it looks just great! yes, I think the tank valve restriction is likely the problem, or at least certainly isn't helping things any.
For anyone who might be interested, here's the detail drawing of what I had in mind for the forward thrust mount lugs. Unfortunately, I haven't a clue as to how to design it with the right spring loading, so the spring pairs will have to be selected experimentally - likewise with compressing them properly. You just have to play around with it, adjusting for the minimum vibration getting through to the solid mount. I hope the drawing is more-or-less self-explanatory; if something's unclear, just ask.
All comments and criticisms welcome.
- Lady Astor Rev04 Forward (Thrust) Mount Lug Detail. Drawing Copyright 2007 Larry Cottrill
- (29.8 KiB) Downloaded 151 times
