LHPJ
Mr.B
LHPJ
Post by Mr.B » Mon Nov 20, 2006 9:53 pm
Ran the Large Hot Pulse Jet in the workshop for some visitors today.
I'm the one with the cap. Frank had a red arm afterwards.
It runs irregular, probebly because of vapor lock in the fuel hose.
Maybe someone can check the frequency?
LHPJ-start.mov
(906.38 KiB) Downloaded 311 times
Mr.B
LHPJ
Post by Mr.B » Mon Nov 20, 2006 9:56 pm
Here are some close ups with the vortex at the exhaust visible
LHPJidle.mov
(1.2 MiB) Downloaded 228 times
Mr.B
LHPJ
Post by Mr.B » Mon Nov 20, 2006 9:59 pm
This is where its full potential starts showing, starting to move on its stand a little and flaring out
LHPJ-evil.mov
(1.15 MiB) Downloaded 252 times
Mr.B
re: LHPJ
Post by Mr.B » Mon Nov 20, 2006 10:30 pm
The nozzle is a modified oilburner nozzle. Very commen in central heating systems.
I cut a slot in the top of the nozzle (across) with a small saw. The nozzle is steel. Then after inserting a feeler gage in the slot, tapped the cut evenly with a hammer. Blowing smoke through it showed the uneven gap that was then corrected with the above method. The nozzle screws down under a slight angle in the CC, spraying across and slightly into the intake. fuel is regulated by opening a still very crude ballvalve, allowing the liquid propane into the preheater on to the nozzle.
Mike Spike
re: LHPJ
Post by Mike Spike » Tue Nov 21, 2006 3:24 pm
Awesome! How did you do the CC? I can see that It's made from two halfs, but how did you make those? Once again awesome! like the growling sound :D
If it doesn't fit, use a bigger hammer!
Mr.B
re: LHPJ
Post by Mr.B » Tue Nov 21, 2006 4:59 pm
The CC is an old stainless DDR made compressor tank.
Mr.B
re: LHPJ
Post by Mr.B » Fri Nov 24, 2006 10:51 am
I was still hoping if someone could figure out the frequentie of my machine? Thanks!
